Question about Olympus WS-100 Digital Voice Recorder
It keeps telling me i only have 40 min of record time, where are the 27 hrs?
I have erased all the files and it still tells me 40 min remain when i want to record. i have not been able to record some key speeches. what should i do?My ws-100 tells me that there are only 40 seconds left, then stops and says full after those 40 seconds. I have reformated the recorder, still same problem. This happened after I down loaded some files onto my mac, as I have often done, then, I forgot to hit eject and just pulled the recorder from the mac usb port. I have done this numerous times without a problem, so I do not think that is it.
I did erase the files from the mac and it seems that the ws-100 doesn't know they were ereased and I cannot find a way to fix this.
Any ideas would be helpful.
The recorder works fine, so wish not to replace it. If I must get another one, any suggestion as to what recorder to get?
  • royozanne Jan 13, 2009
    Olympus tells me to send in the recorder and they will see if they can fix it. This I will do since you have no other idea.
    I am dissatisfied with your service in that I first posted in December and paid for 24 hour service. I got no reply until I reposted and complained, then you ask me to check with customer service at Olympus. That is ok, but not what I would call a tech solution. Please refund my $9.95.
    Thank you.
    ps, I am glad to know that you exist and I will probably look in again someday if I have another problem.
    Roy
  • 177 Answers
Hello and Welcome to FixYa!,
It sounds like there is Corrupted Data on the HDD of the CamCorder.
Take it in to Olympus For a Repair!
http://www.olympusamerica.com/files/WS100200Sman.pdf - Is The User Manual
Hope this helps --P3NGYJ03
Posted on Jan 13, 2009
  • 153 Answers
Format by connecting to pc
and again forman in ur device after unplugging wit pc
tat must work if it doesnt reinstall the software
    President:
  • 948 Answers
If you look at your instruction manual at http://www.olympusamerica.com/files/WS100200Sman.pdf you can see the following - "1 Before you detach the recorder, turn the
POWER switch OFF and make sure that the display is turned off.
If you detach the recorder before the display is turned off, data may be damaged."
This is likely what happened and can only be fixed by reinstalling the software. But Olympus does not offer procedures for doing that. :( At any rate, most mp3 players today also allow voice recording and have ten or more times the memory that your recorder currently has. Sandisk e260 is a reasonably priced mp3 player that I use. Good luck to you.
Posted on Dec 31, 2008
  • 142 Answers
Did you try looking in the troubleshooting guide to help with deleting these items. You can alse try Olympus' customer support.
I recorded a 4hour voice, and my battery ran out on the first hour. and when I erase the 4hour recorder. my recording capability went from 4hours to 1 and a half...what happened? how to get it's memory...
I turned my recorder on one day and only had 20 min of recording time and it was nothing on it took me awhile but i figured it out you have to put it on your pc and reformat it when i did that i got back my 26 hrs of recording time hope that helps
Jul 20, 2010 | RCA RP5022 Digital Voice Recorder
Folder all appear empty but remaining time indicates files
to recover files conect it to the computer.
go to my computer look for the files you want to save place it to drive c: and make a folder for that files.
reset your recorder. after transfering the files to the computer.
still has the problem.
reformat the recorder.
Feb 05, 2008 | RCA RP5010 Digital Voice Recorder
How to delete messages on the RCA RP5120 dig. voice recorder
This is a transcript from the User Manual you can find here, along with other documets, Faqs, and software for you digital recorder:
http://www.rcaaudiovideo.com/product.aspx?product=393
Erasing selected file:
To delete a file:
1. Press MENU repeatedly to select a folder (A/B/C/D).
2. Press or to select a file.
3. Press ERASE once and DELETE will fl ash on the display.
4. Press and hold ERASE for three seconds to confirm deleting
To avoid accidental deletion of all fi les, make sure you press ERASE only when you are reading the time duration of the undesired file instead of the remaining
recordable time of the player
Erasing all files in a folder:
To delete all files in a specific folder:
2. While playback is stopped, press repeatedly until ALL appears on the display.
3. Press ERASE and DELETE will fl ash on the display.
4. Press and hold ERASE for about three seconds, all files in the selected folder will be erased completely.
Jul 28, 2009 | RCA RP5010 Digital Voice Recorder
Remaining recording time VERY short for no apparent reason
check how many different folders you have set up. just because you erase all in one folder, there can be other folders.
Find the manual reset for reformatting the recorder.
Jan 25, 2009 | Olympus WS-110 Digital Voice Recorder
Olympus VN-480 digtial recorder - can't get my files to play back
if the power is interupted or improperly unplugged from the computer, the files may be corrupted... try to play the files and while playing move them to another folder... this may get your files back... else you will need to clear the recorder by pressing stop and erase at the same time for about 3 seconds.
Jan 19, 2009 | Olympus VN-480 Digital Voice Recorder
Hold down the 'Menu/Folder' button until it flashes "menu". Then press fast-forward until you get to "FORMAT". Press play, then it will say 'no'. Press FF to get to 'yes' and press play again. You'll have to do that twice, because it will ask you if you are sure.
It worked for me...
Oct 19, 2008 | Olympus WS-100 Digital Voice Recorder
Saying it only has 59m18s mins left...but its empty!!
format recorder and it will clear all files including corrupted ones... try to safely remove hardware before actually unplugging the device from computer
Apr 13, 2008 | Olympus WS-300M Digital Voice Recorder
Recording Time
I have one of these recorders, I actually have 4 or 5, since discontinued I believe, and one is stuck at 43 min remaining.
I think that problems start when you remove the battery while
the recorder is / was in the process of recording (or in play mode) I now press stop while recording before opening the battery case to switch a battery
Mar 04, 2008 | Olympus WS-100 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
Dec 11, 2007 | Olympus DS-2 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
