Question about HP DeskJet 6840 InkJet Printer
Don't know how to get my hp deskjet 6840 to print wirelessly
It became disconnected after a power outage from my Dell lat d510
    President:
  • 8,637 Answers
Should have a USB connector and needs to be plugged into the USB port.
Hope this helps. Bud
Posted on Jan 27, 2009
Printer lost static IP address with new router and won't install on network.
Your printer is looking for your old router.
Reset the printer:
  • Verify that the printer is powered on.
  • Press and hold down the Report Page button.
  • While holding down the Report Page button, press the Cancel button three times.
  • Release the Report Page button.
Now, re-connect your printer to you new router.
Source :
Re Can Get DeskJet 6840 To Work on Wireless Network Need HP Support...
Feb 12, 2014 | HP DeskJet 6840 InkJet Printer
Printer communicates "cover is open"
1.Power off printer
2.Open cover
3.closs cover
4.swich on printer
ok
Sep 24, 2011 | HP DeskJet 6840 InkJet Printer
Connected HP6840 to iMac with Ethernet and trying to get it to print. Would like to connect wireless. Am I dreaming or can this be done? Should it not print with ethernet connection?
Hi there.
Actually you can. You can make it wireless if you have a wireless router.
Click this link for the manual on how to.
Hope it serves you well.
Thank you!
Aug 13, 2011 | HP DeskJet 6840 InkJet Printer
Does the HP Deskjet 6840 make copies too!
This unit is a plain printer , it doesn't have any scanning or copier features with it. This is a link for the complete details about this unit.
http://reviews.cnet.com/inkjet-printers/hp-deskjet-6840/1707-3156_7-31115699.html
May 24, 2010 | HP DeskJet 6840 InkJet Printer
Can i make copies of a paper
Hello.
If you have a HP DeskJet 6840 then you won't be able to make copies since it doesn't have a built-in scanner. You can buy a scanner separately, scan the document using the scanner and then print it using the HP.
Apr 05, 2010 | HP DeskJet 6840 InkJet Printer
HP Deskjet 6988 Printer Installed properly. Can be detected by the network (both wired and wireless) BUT WON'T PRINT BECAUSE QUIET MODE IS ALWAYS ON. Puts documents to queue but will not print. Tried all...
Hp printer properties best to do this with the usb attached. in the properties you will find printer name make model and setting go to settings and a list with links on depending on what windows you are using, there is auto shut down (2hr) etc on one of the drop lincs is standard and quiet mode. click to standers and save it should be out of that setting now. if still stuck use this link to fix problem with the printer. HP DeskJet 6520 6620 6840 6940 and 6980 Printers Top Cover Open Message...
Jun 26, 2017 | HP Deskjet 6980 InkJet Photo Printer
Laptop wont connect to printer
Try to re install driver and make it your defauld printer. Check your wireless conection.
Oct 06, 2009 | HP DeskJet 6840 InkJet Printer
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid.
Geezer Geek
May 20, 2009 | HP DeskJet 6840 InkJet Printer
HP printer doesn't work after clearing a paper jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it. What have you got to loose?
May 16, 2009 | HP DeskJet 6840 InkJet Printer
Line in photo when it prints
try to clean the copper contacts on the cartridge and printer with the help cotton moistened with water
Feb 23, 2009 | HP DeskJet 6840 InkJet Printer
HP DeskJet 6840 InkJet Printer Logo
128 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
