Question about HP LaserJet 3055 All-In-One Printer
My printer says that it's not connected to printer server
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
How to connect my printer to a router
This model Canon printer has onlt an USB connection to a computer.
The only way to connect this printer to a router is to install a printer server with an USB connector, connect the printer to the print server and then connect the print server to the router using a LAN cable.
The printer driver needs to be installed on all the computers on your network and then to the printer properties then Port tab and add a TCP/IP port then configure this port with the print server's IP address.
Do a test print and if the test print is OK then printer is installed correctly.
May 29, 2012 | Canon iP2700 Inkjet Photo Printer
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
I have doubt purchasing HP CP3525n LaserJet printer. Can I connect this printer directly to my Linksys SR224 switch with its built-in jetdirect? Or I need to purchase a print server before it can be...
Hello You can connect yo printer with the router, because it has the capability to connect with network , no need to purchase print server,
if you have heavy load of printing over it then print server is necessary.
Good luck
do rate if helped
Dec 02, 2010 | HP CP3525N Color LaserJet Printer
Hi, I connected the printer server GPSU01U to a dlink 524
When you connect the print server to the router, does the lights lit? have you tried to reset the print server (reset button is on the side of the print server). press the reset button for 10 seconds, after 10seconds, while still holding the reset button power cycle the print server (unplug then replug the power cable) then release the reset button. Try to find the print server using the PS admin.
May 17, 2009 | IOGear (GPSR01U) Print Server
Adding a second printer to a d-link priter server
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
Jul 28, 2008 | D-Link DPR1260 Rangebooster G...
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
Print server won't speak to printer
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Oct 12, 2007 | Computers & Internet
HP LaserJet 3055 All-In-One Printer Logo
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
