Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
  • 7 more comments
  • richard355 Jan 01, 2009
    i have the same problem. i have tried everything with no luck. It just died. Help!
  • godwinla Jan 01, 2009
    Power light and opg light blinking green and no picture
  • padmashastry Jan 02, 2009
    Brand new TV. Never turned on. Black screen, blinking green power and OPC lights.
  • thebright4 Jan 11, 2009
    I have a new 37". I worked for ten minutes and now the power and OPC lights are blinking. Unplugging and plugging back in doesnot help.
  • Anonymous Feb 01, 2009
    Same problem.
  • Nurse_G Feb 09, 2009
  • Anonymous Feb 12, 2009
    what do we do
  • Anonymous Mar 21, 2014
  • Anonymous Mar 25, 2014
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Posted on Feb 15, 2009
  • ClevelandRex Sep 09, 2010
    Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light).
    I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit)
    II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem)
    III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board).
    IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board).
    V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board).
    VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Power light blinking no display on lc 32sb24u
Its almost always caused by bad capacitors on the power board. You can get a repair kit or the replacement power supply board from
Feb 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Tv won't turn on green light blinks
First check the power supply for incorrect voltages, and bad capacitors in an around the output side of the power supply. You may have swollen caps inthe power supply area that needs replacing.
Aug 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Sharp lc-32sb24u need owners manual
here is direct from SHARP (appears to be same one Silverdragon just posted seconds before me...)
scroll down to "LC32SB24U Operation Manual 1.63 Mb EXE" and select the corresponding [download] button.
(there is entry for French too just below it)
the downloaded file is LC32SB24U_OM.exe
this extracts to LC32SB24U_OM.pdf
...which is the Sharp LC-32SB24U and LC-37SB24U Operational Manual in English. You need Adobe Reader to view PDF file.
Good Luck!
Mar 10, 2010 | Televison & Video
Sharp lc-37sb24u. Flashing Green Light
Backlight invertor is most likely cause of the problem, in rare occasions defective CCFL lamps could cause similar symptoms. Replace defective parts, reset lamp error counter and you good to go.
Dec 01, 2009 | Sharp Televison & Video
Sharp lc 37sb24u both power and ocp are blinking. power power power and ocp power and ocp power and ocp repeat forever.
I have the same problem. I can get the video by pushing the power button on top of the TV after using the remote and getting the power and ocp light dance.
Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp LC-37SB24U will not turn on
I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
Feb 17, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
1,445 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
