Question about Philips Magnavox 51MP392H Rear Projection Television
I have a Magnavox 51MP392H it looks like its in 3D. How do I fix this
  • lmartin60 Jan 01, 2009
    Ok I looked for the STK392-110 cant find it . Where should I be looking?
  • cootter1970 May 11, 2010
    THANK YOU FOR YOUR VERY QUIK RESPONSE STK392-180 I AM ASSUMING ARE SEMICONDUCTORS
  • Philips Master
  • 5,138 Answers
Replace Both of your convergence ICs STK392-110s go by number on STKs if 110s use 180s if 020s use 040s better ICs other wise use same # on STKs.
HAPPY NEW YEAR!
Posted on Jan 01, 2009
  • ladywinn
    ladywinn Jan 01, 2009
    They are Big black ICs should be on tuner board has big ALuimmuim heat sink they are mounted to will have STK on them also CK all 6.8ohm resistors around ICs STK392-120 still use 180s. cost of IC $7.95 each you will also need heat sink silicon to put on back of ICs . Matts Electronics 1-800-628-1118 or Go to www.matelectronics.com
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
Jul 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
My magnavox HDTV model #51MP392H/17 the year on the back of the tv is 2004 the picture on the screen looks like its in 3D how can i fix it myself. I tried a new cable box it only worked for a few minutes...
The convergence ICs and resistors have failed. You will need to install a convergence repair kit. The Phillips DPTV305 chassis convergence repair kit is the correct one for your magnavox. Its available at www.tvrepairworld.com and the kit contains the 2 ICs and resistors and the CD with repair instructions.
Jun 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a picture with red and green lines maybe alittle yellow as well. What needs to be done to fix it? Philips Magnavox 51MP392H
The tv have a problems known as a convergence problems,it is dead.Tv have colors R,G,B lines misalignments,have colors shadow picture or 3D picture look alike?Yes,the tv convergence board it is dead.Must be repair by replacing like 2 STK convergence ICS and some or all of it resistors too on the tv convergence board.To fixed the tv convergence board to solved the tv convergence picture problems.The tv shop will cost u like $300-$350 for parts and labors.
Jun 13, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have double images red and blue crossing over looks like 3D how do I fix this problem.
Thats a convergence issue. The Phillips DPTV305-DPTV345 convergnece repair kit from www.tvrepairworld.com the kit contains the Parts and the CD with step by step instructions.
Sep 19, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
My magnavox 51mp392h rear projection tv has a yellowish color on both the left and right side otherwise the picture looks fine. recently replaced the convergence chips, which fixed that problem
Its the CRT fluid.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Feb 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
The red in my 51mp392h hdtv screen is out of place
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 16, 2010 | Philips Magnavox 51MP392H Rear Projection...
60 inch maganavox rear projection tv blue color almost gone if it is a bulb where can I buy one
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox Rear Projection 51mp392h convergence resistors
This means you do have some bad resistors low ohms 2.7 most of the time its only 2 of them depends on how long you played set before replacing STKs .
Oct 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
