Question about RCA F25645 25" TV
My TV is completely dead, no power (F25645)
My RCA F25645 TV has gone completely dead.  Is there a fuse inside that might be blown?  If not is there a power supply like in a PC?  Is this something that can be fixed?  Can I do it myself safely or should I take it to a shop? Thanks!
  • lamarjr56 Dec 31, 2008
    My tv died like that also. It's a Panasonic CT-36SC13G.
    Problem Solver:
  • 21 Answers
I would suggest buying a new power supply from ebay or other places.
Posted on Dec 31, 2008
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Jun 11, 2012 | RCA Televison & Video
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
TV is dead
check the sw. and Fuse. Blown fuse might be the cause.
Jun 07, 2009 | RCA 32V420T 32" TV
RCA 42in. Projection TV will not turn on.
check the fuse on the Main filter board ( The board where the power cord attaches to) as that fuse can often be blown and that will cause the set to be completely dead.
Apr 12, 2009 | RCA Scenium D40W20 40" Rear Projection...
No power on tv
I'll think there's a problem with the power supply.
Maybe there's a blown fuse inside, that would be the cheapest solution. If not, you need a repair centre.
Kind regards,
Gerard
Jan 25, 2009 | LG 42LC2D 42 in. LCD HDTV
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
RCA F25645 25" TV Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
