Question about KDS K717s 17" LCD Monitor
Ize of images
The images on this wide monitor make people look short and fat, how can that be corrected ?
  • shadyuk Dec 31, 2008
    The wide screen makes images of people and everything else look short and fat, I tried changing the resolution to 1440 -9000
    but that wont work
  • 142 Answers
Try going to the control panel. Go to visual or picture settings and try adjusting the resolution. Also, try finding and option that will allow for the adjustment to widescreen.
Posted on Dec 31, 2008
  • 124 Answers
Yes. For a widescreen monitor, change your resolution to 1440x900. If you need help doing this, please respond.
  • Jason Edinger Dec 31, 2008
    I hope you mean you changed to 1440x900, not 9000.
    There are several different widescreen formats; try changing to other resolutions that make teh display icon on the properties tab look like a rectangle not a square.
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
I have a 55cm TFT LLED-22FHD TV. The aspect ratio is 16:9. This is too wide and the images appear fat. How do I correct this.
Go to the picture menu and select a different aspect ratio. Auto sizing is useful as the TV will detect the picture size and select the correct aspect ratio, except for letterbox and super wide screen of course as your screen is not the right shape for those.
Hope this helps.
Nov 17, 2010 | Televison & Video
Hi just bought Samsung pdp 42" tday. All fine cept
You need to change the formatting of the display to wide.
Jun 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Acer wide screen monitor 20'' font and images all
Right click on the desktop in a clear area and scroll down to either resolution or properties. From this you can experiment with resolution settings to see which setting best fits your display. After each setting change the computer will ask you if you want to accept the changes, it will give you 15 seconds for each change.
Jun 26, 2010 | Acer AL2016W 20" LCD Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
The pictures are too wide all people look fat
You most likely have a wide screen and the screen resolution needs to be adjusted to suit the monitor.
Go to the Control Panel - Display and adjust the screen resolution until you get a normal image and correct screen aspect screen ratio. Start with a screen resolution of 1024X768 and gradually increase it until you get an image that suits your screen.
Oct 01, 2009 | Acer Computers & Internet
Wide screen images lookshort and fat
Native resolution for a 17" widescreen TFT is ;
1280 x 800
Try that.
(The 1440 x 900 is for a 19" widescreen)
Dec 31, 2008 | KDS K717s 17" LCD Monitor
Distorted images due to wide screen
Hi
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Fran
Oct 13, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
KDS K717s 17" LCD Monitor Logo
37 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
