Question about Vtech Digital Cordless Telephone VT-2568
Phone dead, says no line
We replaced batteries, but the phone is dead, says no line. We checked connections
  • 104 Answers
Phone RJ11 connector (or RJ45 if you use LAN) should be check! The Phone Line usually lost signal here
Posted on Dec 31, 2008
  • 142 Answers
The phone is simply no longer working. try to contact the retailer/manufacturer for a refund/warranty exchange
My uniden phone is not working. All hand sets say Check Tel Line. Will not make or receive calls. Will a dead battery in one handset make all handsets malfunction? Are batteries available?
batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Oct 30, 2016 | Uniden Lands Phones
Replaced alt/ battery 2005 PT cruiser is good but i loose the charge and battery is dead by morning ...even after running my car !
Connect an ammeter and set to the 2 amp scale and check out the current drain with the ignition key removed. Remove a fuse one by one until the current drain goes down. That is the fuse that is connected to the power line that is responsible for the drain. Check all of the accessories, etc on that line for the draw.
In meantime till you resolve the issue just disconnect the negative battery terminal till next time you want to use the car so the battery does not drain.
Sep 15, 2015 | 2005 Chrysler PT Cruiser
One of my extension phones is dead. It's a phone that's not used much so I suspect the battery died but would like to know for sure.
Yes. The battery will go bad if they are not cycled regularly. You should be able to get a replacement from radio shack. Make sure to recycle the old batteries at a drop at lowes so they will not end up in a land fill.
Dec 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
Will my land phone anser machine work even when batteries are dead.
The answering part of the machine will probably work as it is powered by the phone company circuit. If you do not put batteries in the BASE unit, it is line powered and will continue to work if batteries are dead. However, your handsets will not work, they will not ring and you will get no dial tone as they will not transmit a signal . A hint is to replace the batteries with new nickel-metal hydride batteries to assure long battery life if you have replaceable battery capability. Mine have lasted 10 years so far and still going strong!
Feb 28, 2014 | Uniden EXA 7950 Cordless Phone
Phone just wont switch on. seems dead
Assuming that you didn't do anything to kill the phone (drop it too much, get it wet, use it as a doorstop), it could be an issue with the connection between the battery and the phone.
  1. Remove battery.
  2. Using a normal pencil eraser, rub the gold terminals on both the battery and the phone.
  3. Rub the terminals with a cloth to remove any debris.
  4. Try turning the phone on.
If this doesn't work it may be that the battery is dead or the phone is dead. If it's the battery it can be replaced. To check if the phone or battery have gotten wet, look for a small patch of paper on the battery or the phone. Typically this paper will turn from white to pink if liquid comes in contact with it (this is how the cell phone company knows if you got your phone wet when you bring it in broken). If it is pink, most likely the phone is completely dead and not fixable.
Mar 01, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
Hi , The problem with my phone is that even though there is full charge , suddenly all the charge is depleted and the phone dies. I am unable to figure out if there is some loose connection with the...
"The charge is depleted and the phone dies" This happens in two cases....
  1. Your batteries are dead and old. Try replacing the batteries
  2. This can also happen if there is a short-circuit somewhere in the connection.
Try exchanging your batteries with a new one or with another phone of same model. If the problem is gone then your batteries were dead but if it arises again there must be a short-circuit somewhere, get is checked....
Oct 01, 2010 | Uniden 5.8GHz Dual Cordless Phone
ON\OFF buton is not responding. The phone is
The power (On/Off) button is not responding probably because it is broken, the phone is dead, or the battery is dead or drained. Connect the phone to a charger and check whether the phone charges the battery or not. The power button is indeed not responding and broken when the phone charges the battery. The only way to turn on the phone is by replacing the power switch.
When the phone doesn't charge the battery, the phone may be dead or the battery is dead/drained. To revive the battery and verify whether the phone is dead or not, check it here.
Apr 06, 2010 | Nokia 6233 Cellular Phone
My phone will not turn on
Your phone could be suffering from: A dead battery. Replace it. A dead Charger not charging the battery, try a different charger to confirm. If dead replace. A faulty power on switch. You need to confirm and replace it. A dead phone (I hope not). If nothing works then the phone may be dead. Sometimes the connections snap with the slightest of jerks and the phone goes dead. You need to carry out the fault finding and rectify the fault. If it still does not come on then replace the phone. But in this order.
Nov 07, 2009 | Motorola Mobility Clutch i465 Cell Phone
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
I have a KX-TG2226 ohone that has gone dead. No connection to the line. Could it have a battery problem? Yvonne
check the cable and connector. and check the battieries prongs are touching the batteryies
Mar 26, 2009 | Panasonic KX-TG5621S Cordless Phone
Vtech Digital Cordless Telephone VT-2568 Logo
42 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
