Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 will not print multiple pages or multiple documents. Once restarted it will print the files. But then does it again once you try to print files again and you have to restart it. Worked fine for cuple years now and out of no where it started doing this.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Only printing coding
sounds like you have the wrong print driver for the mfp
Jan 08, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Afico 1027 Printer not printing all the pages
I haven't seen such problem in this printer
Anyhow uninstall the printer software and reinstall it
You might have PCL6 driver
Try RPCS Driver from Ricoh Web
How do you clean/service a Ricoh Aficio 1027?
you had to have the ricoh 1027 manual & can be download from any technical ricoh forum esp from copytech.net if you lucky, you can download for free
Sep 12, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 line down middle of page
Locate and check the printer drum. You should be able to see the mark
that is causing the line on your page. It could be s scratch or a ring of
toner that the wiper is not picking up because a nick or something under
it. Try cleaning the drum with a very soft dry cloth and inspect it
again. If the mark is still there the drum will have to be replaced. Do
Not Try To Clean The Drum With Any Type Of Solvent!
Feb 04, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh 1027 but it does work codes sc 548
You have a problem with your fuser - either an overheat, or lack of heat. Can only be reset by technician in a service mode, once it is fixed
Feb 19, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh printer prints nonstop when plugged up& is in code
clear you print files in your print  que
http://www.websitetoolbox.com/mb/copierquestions
Jan 15, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Page counter on RICOH aficio SP C811DN
Enter the menu of the printer pressing once the relevant button and with the up or down buttons find the list test print. Then press once # or OK (whatever the machine has) and you see Configuration page. By pressing once again the # or OK it prints the Config.Page, which somewhere on the top of thw sheet shows the pages printed (first the black and then the colour. Good luck!
Oct 17, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
