Question about Viking VGSC306-4B Gas Kitchen Range
Ignitors on three burners start when using a burner & dont stop
When using the the front right burner the back two burner ignitor start sparking and do not turn off for a longer and longer period of time.
  • rpjordanrph Dec 31, 2008
    Where can you get that and can a consumer install?
  • padoherty Mar 16, 2009
    ignitor in one burner won't stop
    Sergeant:
  • 311 Answers
If you dont have mice that chew and short out wires,you need a new spark moudel
Posted on Dec 31, 2008
  • Thomas Malailua
    Thomas Malailua Dec 31, 2008
    i had my own appliance store 4 10 years,sold it but what you can do is google your model # and you will fine links to parts /God bless
Xl44 top burners light
There are a few things that can do this... First check the burner top to make sure the holes are not blocked. 2nd, Are the other ignitors sparking? If so then try rotating the slack in the burners left and right - this works sometimes. If not then try placing a screwdriver (you holding the handle only) and touch the burner and lean the screwdriver towards the ignitor... making the spark gap smaller. If you have used the ignition without a burner in place the ignition pack will short out inside it and there will not be a spark until the gap is very small. 3rd, are the ceramic part of the ignitors cracked at the base... take care when washing as they break easy if caught on the cloth. The ignition pack works in pairs so having one work suggests the pair of this one is something in the lead if there is no spark... A huge spillover causing a short or a bad earth... check the burners are firmly in place. There is more but too much detail to post here. Good luck
Jan 02, 2014 | Kitchen Ranges
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Ignitor won't spark
Look at the front ignitors that work and look at how they ground. Then, set the back ones up the same way. Make sure the 'arc gap' is the same too.
Jul 02, 2009 | Kitchen Ranges
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking VGSC306-4B Gas Kitchen Range Logo
221 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
