Question about Pioneer PRO-610 58" Rear Projection Television
610 wont turn on heard a pop and that was it
I read about the pc board solider joints is there any way to band aid it temporarilly
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
Jul 28, 2017 | Samsung Televison & Video
Oven won't maintain heat
most likely the relay board. it's a common problem with this range. most repairs are just replacing the relay board (~ $225 part). getting to the relay board isn't easy, by doable by removing the burners, top plate (special tool for burner rings), insulation, another plate(s) with a lot of screws, right two burner lines, then another small access plate. make sure to mark where the wires go, and of course power off. either a relay goes out or a solider joint pops loose. if you have time, i'll would remove the board and inspect the joints (look for the relay with the wire marked "ba"). its goes to the lower heating element. if you see a bad joint, then re-solider it and try the board. (this worked for me). if it looks good, then look for a burnt relay (or you can test it with 24v).
Jan 03, 2014 | Dacor Epicure ERD36 Dual Fuel (Electric...
I have a sharp aquos lc-c5277un. Both the power and OPC lights together blink twice. I tried unplugging it, holding down the volume up and channel down buttons while plugging it in. That left me with a...
Could be either or both. The power supply board probably gas an electrolytic capacitor that has failed. Same goes for the main board. When you can hear a pop, you'll be able to visually locate the failed part. Capacitors must have a flat top on them. Any bulging or domed capacitors need to be replaced.
May 10, 2017 | Televison & Video
Coby 610-2g mp3 player wont read or turn on
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will let your computer see it again & turn on etc.
Please follow these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 20, 2010 | Coby MP-610 MP3 Player
Ball joints been replace and i hear scrubing,clunking. and popping. when come to a stop or taking off. the popping can heard and felt on passerger floor board
I think you mean of the CV joints were replaced, right ? if so , your noise could be coming from your MacPherson strut, or possibly the stabilizer bushings. I would check the suspension components and the steering components of the rack.
Mar 03, 2010 | 2004 Dodge Stratus
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
Mp3 wont start, freezes, pc wont detect usb
I recommend you try the firmware replacement again with the file you can get form the link below. I have fixed several 610's with it.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
Unfreeze Coby 610
Jun 15, 2009 | Coby MP-610 MP3 Player
Jbl sub 135 motorboating b4 warm up JBL sub135 I never heard it called motorboating, but that is a good description of the sound, It's like the sub is trying to output sounds which are not in its range...
Turning the unit on without any input signal, the speaker did the pop and scratching sound. I found on the limiter board ( small pc board on the main input pc board) that there is a wire jumper on the back side of that had a cold solder joint. You will have to clean up the glue that was used to hold the wire on the back side of the board. I just replaced the wire with new one.
Look at the +15vdc off of Q117, I moved it to the left side of the pc board and added a heat sink to the unit. The 1 watt resistor created some cold solder joints that you will have to check.
hope this helps
Feb 19, 2009 | Audio Players & Recorders
Pioneer PRO-610 58" Rear Projection Television Logo
80 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
