Question about Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
I thought the console was warm and bought a new cooling fan from game stop. immediately after installing it, i got no picture but did have sound. I also have the 2 green rings around the power button.
HELP ? !
  • Anonymous Dec 31, 2008
    Have you tried the xbox website the "offical website" it has helpful hints on there to trouble shoot your problem look under support.
    Problem Solver:
  • 7 Answers
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Posted on Jan 01, 2009
My ps3 won't turn on. I try to press the power button and it turns on for 2 seconds, followed by a yellow light where it's normally green and then beeps 3 times before flashing a red light.
Hi pinstripes61,
Sadly it sounds like your system is overheating and shutting down as a precaution. Make sure your system is getting as much ventilation as possible. If your system has been getting enough ventilation it would indicate that something is causing the cooling system of the console to malfunction. It's probably saveable but i would suggest you stop using it and contacting tech support immediately.
Sorry for the inconvinience,
Luchen
Mar 19, 2011 | Sony Playstation 3 (PS3) Console
I have the red ring of death
okay dont panic YET!
Try this try overheating ur xbox360 by stopping the fans ge 2 sticks small enogh to stop both fans i used two darts most people use q-tips well any way wen uv stopped ur fan s the red light s on ur xbox will still have 3 lights wait untill the lights have only 2 lit on the left hand side of the ring this is wen ur xbox will have overheated let it cook for 1min if that the unplug leave for 15-25mins to cool to room tempand boot it back up GREEN LIGHTS
Nov 27, 2010 | Microsoft Xbox 360 Console
I have a new console but have not used it for about 3 weeks, the console switches on but there is no green ring around the power button and it wont connect to any controller.....any ideas Jas
if you are using hdmi lead, make sure it is correctly inserted, and that you have pictur on screen and also the settings are configured for this, try using the av lead.
Jun 23, 2010 | Microsoft Xbox 360 Console
My xbox 360 has a red ring around the power button.... how do i fix it????
If you are technically minded, this is very simple to fix, the hardest part is taking the consle apart.
there are many kits with self explanatory instruction available on the web, but try to find an all metal kit, ones with nylon washers only solve the problem in the short term.
once the case is opened, u need to remove the fan shroud and fan assembly, then remove the motherboard from the casing. turn the board upside down, and CAREFULLY!!! prise off the 2 silver x clamps from their locating lugs, the 2 processors/heatsinks can then be removed.
Clean all traces of thermal compound off the board and heatsinks using either white spirit or an alcho solution, if using w/spirit dry thoroughly.
apply new thermal compound, just enough to cover the processors on the board, and using the kit bought from ebay position the screws and washers and re-attach the heatsinks.
Now u need to plug the xbox into the mains, and attach the av cable, turn the xbox on, but dont reconnect the fans as u need the heatsinks to get hot and the console to overheat, this will take between 30 seconds to a coupe of mins, and when hot enough the console will show 2 red lights.... this is perfectly normal!!!!
once the 2 red lights appear, turn the console off by pullin the power cord out, do not use the on/off button. allow the console to cool for about half an hour. reassemble the xbox and hey presto u should now have green lights and the console fixed.
Mar 12, 2010 | Microsoft Xbox 360 Console
My xbox 360 has the green ring and it turns red and shuts me off the game what is wrong .
that is called the red ring of death which is basically the processors overheating, you can try purchasing an intercooler unit which connects to the back of the console and you connect your power supply to it that way you'll have a constant fan cooling your machine you can get one from game stop, walmart etc. for about $20 if the red ring stays on after that you would have to send in the console for repair microsoft generally charges around $140 360 pros charge about $90 and provide a 90 day warranty you can contact them at 800 618 7215 for more info. Hope this helps
Aug 05, 2009 | Microsoft Xbox 360 Console
No picture just sound
ur xbox 360 is in high def turn ur xox 360 with ur controller and hold r trigger and y button together till it turns on. if it dont work than u got the rings of death try this there are fans in the back of ur xbox 360 put a straw on each to stop the fans from spinning wait till it has two red lights than disconected from the back and wait 20 minutes and try it see if it work. if it work this is just a temperary fix.
Jul 02, 2009 | Microsoft Xbox 360 Elite Console
No Red Rings, can't turn on
try difrent powerbrick and take the extra fan out
Jun 18, 2009 | Microsoft Xbox 360 Console
No red rings ,but no picture on t.v.
you may have to wait until there is a thing that goes green and goes around then that makes it load and it will work
Jun 15, 2009 | Microsoft Xbox 360 Console
My playstation 3 fan runs constantly and don't seem to stop unless the power is off.
Hi my name is Juan and I am here to help you on this the fan on this unit is allways on especailly that ou have the 60Gb the ps3 with the 80Gb and 60Gb models they do get verry hot and for this reason the fan won't stop it may even increase speed as heat builds up if the fan on those 2 units that I mention stop working for only 15 seconds belive me the next thing it can happend is playstation will shuft down immediately and it would not start the next time so don't worry for the fan try to make sure you have a good clearance around the ps3 to keep it cool
Mar 23, 2009 | Sony PlayStation® 3 (60 GB) Console
No Power with 3 red light
hmmm.. The Ring of Death.
The 4 rings mean power faliure.
The 3 rings mean the CPU has been melted.
The 2 rings mean there is a CPU overheat error.
The 1 ring means there is an internal error.
Hope this could of helped you.
Jun 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
107 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
