Question about RCA P60920BL 60" Rear Projection Television
RCA Big Sceen P60920BL Chasie PTK195KC won't power on
It has been a great tv. It hardly ever was turned off. We have never had to have it worked on. One day it shut off and never came back on. I think I remember hearing a beeping sound so I finally unplugged i.
SOURCE: RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
SOURCE: rca m50wh725 rear projection tv.
Blinking 5 times means the lamp is dead.
Posted on Jun 22, 2008
ladywinn
  • 5138 Answers
SOURCE: front panel
Either replace front panel board or all contact switches on that board the one with vol- vol+ ch- ch+ power, menu.
Posted on Dec 22, 2008
SOURCE: 52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Posted on Jan 30, 2010
  • 30 Answers
SOURCE: rca P60920BL starts steady chirping when plugged in
This is usually the flyback transformer (IHVT-integrated high voltage transformer) and the HOT( horizontal output transistor) The transistor will read shorted, with a multimeter, if it is bad. It is mounted to a heatsink straight back from the flyback. It may have a metal clip that holds it tight to the heatsink.
It is a pretty easy fix if you can solder.
While you have the board out, check for any discolored resistors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
Posted on Mar 02, 2010
Hi I have a Philips 40PFL3705D/F7 LCD TV. The picture shuts down after a while. Could be 3 weeks, 3 days or 3 hours of watching TV. Still have sound.
Maybe a thermal problem or there is something apart loose even use cold spray, manipulated by slight shaking or tapping components.
Oct 31, 2015 | Philips Televison & Video
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Mar 03, 2009 | Samsung HLT6176S Television
Older projection tv won't turn on.
id replace the tv its 15 years old and past the livlihood they usually have. it would cost more in parts to repair it than to go out and buy a new one. im sure you probably already know that though. have the tuner checked but i dont think it will save the tv but if it comes on when the cable box isnt hooked up then the problem could be in the tuner. its hard to tell. the tuner is about 100.00
Dec 29, 2008 | Televison & Video
Tv won't turn on
I hear they have weak power supplies
Sep 05, 2008 | Samsung TXN3271HF 32" TV
T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Dec 03, 2007 | Sony KV-36XBR400 36" TV
Televison & Video Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
