Question about Epson Stylus Photo R220 InkJet Printer
Epson r285 i just bought an epson r285. everything loaded ok, and when i try to print, it seems to work ok. but doesn't actually print anything. i tried cleaning the heads, changing the inks, but nothing. can you please help. steve
  • stevebmw2001 Jan 01, 2009
    tried the inks several times, thanks very much for taking the time to help, cheers...
  • 1,447 Answers
Try reinstalling the inks, make sure you here a click when you press it down. If all fails you are having a hardware issue. call epson for replacement.
Hope this help
Posted on Jan 01, 2009
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
May 30, 2014 | Epson TM-U220 Matrix Printer
First time visitor. Entered Epson Stylus Photo R285 into search box. As I scrolled down what I presume is the result of my search, there were answers for everything BUT my R285. I use a CISS kit on my...
Welcome to FixYa.
This occurs when the ink pad counter times out and is supposed to be a dealer service to drain the waste reservoir and replace the pad.
The only thing that you can do is try to reset the printer. Please do the following:
  • Turn off the printer by pressing the power button. Check to make sure that the print head is in the default position, to the far right of the device and locked in place.
  • Hold down the paper feed button. Turn on the printer by pressing the power button.
  • Release the paper feed button as the paper feed light starts to flash. Immediately hold down the ink-drops button for 15 seconds.
  • Wait for the printer to complete its test run. Turn off the printer and then turn it back on once more.
Thank you for using Fixya, keep me posted.
Aug 23, 2011 | Epson Stylus Photo InkJet Printer
Epson R285 need service utility
It sounds a lot like you have managed to reset the printer using the R290 adjustment utility and it now thinks that your printer is an R290 printer.
As a result it's rejecting the yellow cartridge (presumably the first to read empty since you reset the printer) and expects you to provide R290 consumables.
The only fix that I've heard suggested (and I'm still waiting to hear if it worked) if to get someone with a valid R285 to use the same adjustment utility to make a backup of the EEPROM data (nothing else), save this file, send it to you, and then for you to restore that same data to your own printer EEPROM.
As I said, I haven't heard if it works and I could be wrong about the cause but as I provide waste kits myself and have already had quite a few people report a similar issue I suspect I'm about right.
Hope that helps.
Jul 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson r285 uses all colors to print black
To print in black ink only mode on windows, please follow these steps:
  1. Right-click the drv_taskbaricon_1.gif printer icon in the lower right corner of your screen (taskbar).
  2. Select Printer Settings. A preferences window will appear.
  3. Click the Advanced button in the lower right corner of the preferences window (if you see a Basic button in the lower right corner of the window, skip this step).
  4. Click the Black Ink Only check box.
  5. Click OK in the preferences window.
If you’re using a Macintosh, you can’t set up the printer to print in black by default.
However, your printer will still use minimal amounts of color cartridges to prime the system when your printer is in the initialization stage when turned on. Your printer also mixes all the color cartridges to make up another black, that is to prolong the life of the black cartridges.
Apr 29, 2009 | Epson Office Equipment & Supplies
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson STYLUS DX4400
Dump then program. Start your pc again wtih printer plugged in. Let it install program automatically.
Feb 21, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Printing issues with Epson r285
hi! try this! 1. go to control panel, select the printer, then right click the model of your printer, select properties, then select printing preferences.    in printing preference, select effect, then check the box of vivid photos. If you check vivid photos it will add enhancement to your printout. But thats not it, 2. open your photoshop, find your color settings, set your RGB color to (sRGB IEC61996- 2.1) then you CMYK color to (U.S. Web Coated (SWOP) v2) then off all your Color-management Policies and don't mind anything. 3. After your Edit your photos from RGB, then convert it to CMYK, then try printing it.
Dec 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
EPSON STYLUS CX3900 MacBook MacOS x tiger
I use the CX3800 talking to a printer connected to a PC on a network and it seems to work fine. You can also download drivers from OSX from epson's web site
Jan 08, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Epson Stylus Photo R220 InkJet Printer Logo
238 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
