Question about Monitor Audio FastBass FB212 Subwoofer
Monitor Audio FB212 buzzing
FB212 does not go automatically into standby mode, so when there is no signal coming from the receiver it still buzzes, like 60Hz. If I manually switched of and than put back in Auto mode it goes to StandBy, red light comes on and its silent, but as soon as signal comes in or I manually move it to On and than back to Auto, the green light for On stays and buzzing is there. It only stops if Offed manually. Help!
Apparently there is an issue with the 10000uF 80V capacitors. They are poor quality ones and the issue is that the dielectic forms hydrogen internally which eventually blows the dielectric out.
Posted on Jun 28, 2009
  • alastairbell Jun 28, 2009
    Just replaced the 4x10000uF capacitors on mine and its fixed it.
Monitor Audio FB212 Subwoofer need Schematic/service manual. I have the amp has been burned some resistor, i can not see what value of them. Please scan send to laidungvn@yahoo.com, Thanks so much
Posted on Aug 12, 2012
How do i fix the buzzing on my nad t741 5.1 receiver?
Bad screening on your cables.
Braided cable coax touching signal cable
Wires in close proximity to power wires
Interference from 'always on' appliances like fridges, freezers and heating boilers.
Disconnect each lead in turn. If that doesn't fix it, it is an appliance.
Apr 16, 2016 | NAD Audio Players & Recorders
Hi, I have a sony rear projection TV when i try to turn it on it clicks ,buzzes for a for seconds then goes into standby, i took the back off and the buzzing is coming from the ballast board, in particular...
Hi:
That is correct that canister is the lamp, seems its trying to light, If you have not replaced the lamp since you purchased the unit then this is the perfect time to do so. This buzzing from the ballast is normal just means it has received signal to light the lamp. Just start by replacing the LAMP>>>
Nov 10, 2010 | Televison & Video
I have recently acquired a old Denon AVR3801 Home cinema Receiver. I have plugged it all up and switched it on, but although the system seems to work quite nicely, the amp itself makes a buzzing/humming...
The solution of leaving the thing on all the time would certainly work, but most of the time a buzzing sound inside a relatively robust audio amplifier is being caused by the huge transformer coil in the thing. Or wires that are in close proximity thereto.
In some ways, you're blessed that the buzzing is coming from the unit itself, and not through the loudspeakers.
Mar 06, 2009 | Denon AVR-3801 Receiver
I have a hum or buzz on AM and FM bands only.
I had the same problem, but it is not the tuner module! An exchange of capacitor C899(100μF/35V) on the standby board has resolved the problem. Under a dollar from an electrical store and you are all sorted. 10 minute fix for those with a soldering iron.
Feb 18, 2009 | Sony STR-DE685 Receiver
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Harmon Kardon Receiver BUZZ
My receiver started having same problem after about 2 years from install. Any ideas?
Oct 14, 2008 | Harman Kardon AVR 110 Receiver
Noise from onkyo 505e
you can try to turn the stecker around some times this helps as some equipment is sensative to plus plus instead of plus > min connections
Apr 29, 2008 | Audio Players & Recorders
Buzzing in speakers
First, if the buzzing came in gradually, I would suspect the filter caps. If it started suddenly and goes up and down with volume control, I would think it is in signal path - maybe the dsp board.
Apr 23, 2008 | Kenwood VR-405 Receiver
Buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Jan 06, 2008 | Pioneer VSX-D409
Buzzing from vr 306
the power transfomer has a loose lamination in it. Gnerally too expensive to replace... check all the mounting screws to it are tight, sometimes a washer under 1 corner may help to rid the buz. ..it may be the standby transfomer also, These can be replaced for much less than a mains transformer.
I have solved this sometimes in the past by giving the laminations of the transformer a strategic wack with a hammer. .
Nov 12, 2007 | Kenwood VR-407 Receiver
Monitor Audio FastBass FB212 Subwoofer Logo
587 people viewed this question
Top Monitor Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monitor Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
