Question about Akai LCT3215/26 32 in. LCD Television
TV problem I turn on my Akai tv, and is makes a high pitch noise, as soon as teh Akai logo shows up, the tv turns off. Model LCT3285TA
  • Anonymous Mar 24, 2014
    I got an AKAI LCT2016 TV from a friend and it worked fine and now that I'm hooking it up myself it wont turn on. Any suggestions on how to get it to turn on?
    Genius:
  • 1,074 Answers
Take your tv to a tech your power supply is faulty or the xray protection circuit.good luck.
Posted on May 06, 2007
  • CHRISTOPHER POMADZI Aug 09, 2017
    When you switch on your Akai TV and the display come and go stanby ,how would you solve this problem
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
AKAI lct3285ta will turn on, show the akai logo and then turn off
Update the firmware. It is corrupted. Do a hard reset to this set, and then check. Sometimes it might help you. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 21, 2017 | Akai LCT3285TA 32 in. LCD Television
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
Durabrand tv wont turn on!
My Daughter has the same problem with hers. That high pitch noise your hearing is coming from
a transformer on the inside it means the transformer went bad and has to be replaced.I hope this helps a little.
Jan 02, 2009 | Durabrand DU1901 TV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai LCT2662
You're getting some feedback on the secondary transformer - most likely... Try to isolate where the pitch is coming from and see if it's harmonic. May just need to be glued down or have some leverage place against it...
Bill
Apr 01, 2008 | Akai LCT2662 Television
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Oct 30, 2007 | Akai LCT3285TA 32 in. LCD Television
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
Televison & Video Logo
210 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
