Question about Aurora Electronics Aurora 5 Sheet Strip-Cut Paper Shredder
BROKEN GEAR AURORA MODEL AS501X-MS . WERE TO BUY THESE GEARS?
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
Purchase gears
This is an inexpensive, light duty shredder. Products such as this are considered 'throw-away products' ; when they break, you throw it away and buy a new one. Larger, more expensive commercial shredders are repairable.
Jun 21, 2014 | Aurora Global AS501X-MS Shredder
My schreader was working and just stopped schreaeding . It is not jammed . Do you know what might cause this . How can I fix it ?
There is a very small micro switch on the bottom left hand corner of the unit. This switch needs to sit securely on a mall shelf protrusion that comes out of the base. If the switch isn't properly pressed the unit will not operate. If you search the bottom corners you'll see the tiny switch. If you press it the shredder will begin to work again. You just have to reseat the unit into it's original base and the little shelf will press it for you.
Jul 18, 2011 | Aurora Global AS501X-MS Shredder
I need the gear that runs off the metal gear on motor
Many people have looked for parts for their shredders, only to find that there are none...
Seems as though they build them to be thrown out and replaced...not repaired...
Sorry, but there are no replacement parts for most shredders...
heatman101
Jun 24, 2011 | Aurora Global AS501X-MS Shredder
I need new gears for my as501x-ms aurora paper shredder. Where can I purchase them?
Call Aurora customer service at 1-800-327-8508 USA
internationl only 1-310-793-5650
Jun 23, 2011 | Aurora Global AS501X-MS Shredder
I NEED INTERIOR MACHINE PARTS TO MAKE REPAIRS ON MODEL # AS501X-MS. CAN I ORDER REPLACEMENT PARTS? I NEED A PARTS LIST.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Mar 02, 2011 | Aurora Global AS501X-MS Shredder
I have the Aurora shredder, model number AS501X-MS. What maintenance is required. Should I oil/lubricate it?
Clean it (unplugged) with a vacuum periodically. Dump the can regularly - dont wait for the light to tell you it is full. Get some shredder oil at the big box store and follow the directions on the back
Oct 16, 2009 | Aurora Global AS501X-MS Shredder
Has worked perfectly, but now won't run at all.
Verify the alimentation (power supply) parts,and the mechanical part gears.I thing onesome gears is blocated.
Sep 01, 2009 | Aurora Global AS501X-MS Shredder
I have a as501x-ms that jammed. all the paper has
Have you tried running it in reverse?
Also, unplug it and make sure that ALL of the paper has been removed from the shredding teeth before you try it in forward mode again.
Jul 09, 2009 | Aurora Global AS501X-MS Shredder
Shedder one works
This is an issue with the paper feed sensor which may be a electronic eye or a mechanical switch if it is mecanical you may just have to jiggle the switch a few times, occasionally paper may get stuck behind it not letting it activate. If it is electronic you have bad sensors or bad pc board and you'll have to contact the manufacturer for further info.
Mar 07, 2008 | Aurora Global AS501X-MS Shredder
Aurora Electronics Aurora 5 Sheet Strip-Cut Paper Shredder Logo
275 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
Dabu42
Level 1 Expert
chargerhp
chargerhp
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
