Question about Microwave Ovens
Hello; my oven has been working perfectly. I tried to use the defrost. For doing that I pushed several different pads. Finally with the help of the Owner´s Manual I coudl use the defrost, but the oven is not working for heating foods. How can I use it for heating foods as I have done for 15 years... Thanks Juan My microwave oven is : SG-4851-10/03 serial N? HG21904273.
  • 833 Answers
It sounds like what you've done is locked up something in the timer. I'd unplug the unit., wait a few minutes and plug it back in. If that doesn't do it, I'd look at whether your unit has some kind of child's lockout that you may have activated. Not that...we've got to look at more issues.
Posted on Dec 31, 2008
How do i defrost by weight. I can't bi pass the express key function
mine if I enter 1 it's .1 enter 1 0 tis 1.0 lb
16 would be 1.6 lbs. not 16oz.
8 oz= 1/2 lb or 5
a model # and make would help a bunch!
hope this isn't as clear as mud?!
Feb 01, 2018 | In Microwave Ovens
Cant get the defrost cycle to work, lost the instructions
You push the defrost button then the amount of meat from the number pad
Feb 14, 2011 | LG MS-0744Y Microwave Oven
Keypad does not always work
HI. you will need to replace this malfunctioning key pad asap. this will require you to disassemble the unit, in order to reach the actual touch pad board. It is not an easy task, and i recommend a professional tech, if possible.
Aug 26, 2009 | Maytag MMC5000 Microwave Oven
After pushing the defrost button how do I get the microwave to turn on
Kept pushing buttons until we finally hit the right combination.
Jul 19, 2009 | Sharp R-220HW Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
How do i set the time on my microwave?
check istruction manual, and try to set cntrol panel . that is very easy to operate, try one more time ...
Aug 20, 2007 | Emerson MW8675W Microwave Oven
Manual for sharp carousel R-230 AV
Please walk me through the defrost on my sharp micor
Sep 21, 2006 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
