Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune froze on boot up this morning. Reset buttons won't work nor will any others. Tried charging battery to no avail. ii have the same exactproblem as bravo3do. i let it die and then charrged it up and it did the ame exact thing... can u be more specific with the solution plz???
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
My Zune 30 has been working fine today. Should I be worried?
Nope, your Zune is fine and will continue to work as long as you do not connect it to your computer before noon GMT on January 1, 2009 (7 a.m. Eastern or 4 a.m. Pacific time).
Note: If you connect your player to a computer before noon GMT on January 1, 2009, you'll experience the freeze mentioned above—even if that computer does not have the Zune software installed. If this happens, follow the above steps.
What if I have rights-managed (DRM) content on my Zune?
Most likely, rights-managed content will not be affected by this issue. However, it's a good idea to sync your Zune with your computer once the freeze has been resolved, just to make sure your usage rights are up to date.
What if I took advice from the forums and reset my Zune by disconnecting the battery?
This is a bad idea and we do not recommend opening your Zune by yourself (for one thing, doing so will void your warranty). However, if you've already opened it, do one of the following:
  • Wait 24 hours from the time that you reset the Zune and then sync with your computer to refresh the usage rights; or
  • Delete the player's content using the Zune software (go to Settings, Device, Sync Options, Erase All Content), then re-sync it from your collection.
Posted on Jan 01, 2009
MY ZUNE IS FROZE ALL IT SAYS ZUNE ILET IT DIE AND THEN GHARRGED IT UP AND IT IS THE SAME
Posted on Dec 31, 2008
Zune frozen with logo
Let the battery drain completely and then plug into computer. There was a leap year glitch from Microsoft and the fix is working today. Ours froze yesterday and it's OK this morning. This only fixes those that froze Dec. 31st.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
How to unfreeze my zune???
Microsoft is aware of the problem. Everyone has the same problem. It is a bug in Zune firmware. One option that works is to disconnect the internal battery and that will reset the system. Here is a link to the problem
http://www.tomsguide.com/us/Zune-Media-Player-Bug,news-3236.html
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune froze won't reset tried back button in unlock and held top of zune button but did nothing.
Followed explanation on Yuotube on how to disconnect battery. Rebooted Zune and all works normally?????
This is the first time I have had any problem with Zune in 12 months and very grateful to Fixya in helping me find the solution.
Zune 30GB froze
pull the case apart, unplug the battery pack for about 30 seconds, then put it all back together. it's not near as hard as it looks.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
There's a fix:
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
130 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
