Question about Sunpak (SDPF-070AW-0US) Digital Picture Frame
7" sunpak frame wont recognize usb connection
I plug in USB cord and the screen lights up, I can then select photo, then the only thing lit up is memory cannot select USB. If I unplug the USB cord the screen will go black and come back on when I plug USB back in. Also. connecton not showing on computer.
  • Anonymous Jan 21, 2009
    I have the same problem.
How do I get my computer to recoginze the connection of my USB?
Posted on Apr 22, 2009
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Plug USB cord into computer to transfer photos..on camera screen it says mass storage and the USB is not recognized
Plug camera in any other USB port of computer as some time one particular USB port stop to recognize it.
Oct 20, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
How to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
May 11, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Usb photos not showing in the frame
if there is a cable to connect the frame to the comp put the carf in the frame and hook up the frame install picts through the frame. that is how most of them do it. it converts the pic to a different format easier for it to read. it wont just read drag and drop jpg files. it also formats the card to it own specs.
May 03, 2009 | Computers & Internet
Hardware not recognized by computer
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Feb 23, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
I have a Quantaray 7" digital photo frame by Sunpak. I am unable to adjust the brightness. It stays dark all the time. It was the last one Wolf had and the direction where missing from the box. The screen...
On the opening frame when you turn it on Scroll through the icons to "setup" . Press enter.. A screen will come up sayinf "set up menu-photo setting"..Scroll down the left column to the center multi color icon and press enter. Press the right arrow on the handheld. In the grey box that comes up you will see various controls.. The third on the list is "brightness" . Press enter and then right arrow .. Scroll to setting you desire. (Normal, bright or soft are offered).. Good luck..
I also posted a question that you may know the answer to. How do I load photos on to the unit from my computer. I see there is a USB port on the Sunpak and I have a USB port on my computer .. but no cord with 2 USB port ends?
DH-L
Dec 25, 2008 | Quantaray 7-Inch Digital Picture Frame -...
I am not able to put the pictures on the internal memory?
Had this same problem and found this solution after digging on this forum, and it worked...you have to pay attention to the "Device" you are pasting to. It's cumbersome for copying mutliple pictures, but with persistance, it works.
"I have found that when you have the source of the photo files connected to the picture frame and are viewing from the menu it says "USB" Select the photos you what to paste by following the instructions and then change the "Device" to "favorites" and the paste by pressing the "enter" button.You can only paste about 10 files or photos at a time...so if you have allot it take a while. hope this helps"
Dec 17, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Just bought a sunpak 7" photo frame. Trying to put pictures from flash drive onto the memory on frame. How do i do it?
Dec 03, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Nov 25, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Sunpak (SDPF-070AW-0US) Digital Picture Frame Logo
504 people viewed this question
Top Sunpak Photography Experts
Andrew Taylor
Andrew Taylor
richie46
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
