Question about Cooktops
Clock & Timer Malfunction
The clock/Timer isn't working..It rings ever 1 hour 59 Min. We can't stop it even though the oven is not in use or usable..It just started malfunctioning in the middle of the noight and I can't shut it off..Can someone help.. I'm getting uo to reset it every 2 hours approx.. HELP!!!
  • carol_005 Dec 31, 2008
    Thank you..I'll give it a try! Happy New Year!! :-)
  • 311 Answers
You can go to the back of the clock and clip the buzzer wire[one is allyou need] tape it up.other wise you need a new clock
Posted on Dec 31, 2008
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Stove is fine but the oven does not heat.
Possible faulty element. What about the clock/timer? Is it on the right setting? It should be in manual mode. If the timer is okay it will generally be an element or a faulty connection at the element.
Feb 09, 2011 | GE Cooktops
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
Oven clock / timer
This could be a very pricey repair. Depending the make and model of your part. Try to contact the parts department for your oven and see how much they say a new clock/timer will be. The higher end models could require a 300 - 400 labor just to install the part. Most companies will not do it if you have the part so be sure to ask first.
Sep 04, 2009 | Bosch Cooktops
Whirlpool Cooktop will not reset
Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
Dec 27, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Cook top
Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
May 28, 2008 | Frigidaire Cooktops
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
82 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
