Question about Nikon D1X Digital Camera
NIKON D1X won't take pictures
We get an FEE error and the battery flashes. Could it be a bad battery and the camera won't take the picture because not enough battery power. It was charged for 6 hours and it only has half the battery icon filled. Do we need to replace the battery to get the camera working again?
  • 2 more comments
  • damien98499 Dec 31, 2008
    Hi, we tried that and it didn't work. we even switched the lenes
  • arceye10 May 11, 2010
    Hi, the FEE error relates to a problem on the aperture ring. Have you taken the lens off?
  • Mick Carruthers
    Mick Carruthers Nov 10, 2012
    must be on F22 or F16 on the lens - if not a G ( Gelded lens with no aperture ring ) some Nikkor lenses have a lock using a switch to keep the lens at minimum aperture - the camera's meter must know what it is
  • Mick Carruthers
    with a Nikon D1x the batteries must have refresh charges at least every 3 weeks , this means a deep discharge of the battery and a slow charge back up - the problem is that Ni - Mh ( Nickel - Metal Hydride ) batteries develop a memory problem , basically the battery has to be taught if you will what full really is - I'm sorry if you keep doing ordinary charges from part used ...the battery will get " confused " as to what full is meant to be . Ni-Mh is a bit ? of a old fashioned battery type for a digital camera . More modern cameras have Lithium L-ion batteries which have no memory issues . You can get the voltage with a multi meter . Basically inside the D1x battery there are " industrial " batteries that are a bit shorter than AA batteries soldered together . Obviously eventually any battery can only take so many charge cycles and has to be replaced . There is some sort of chip controller inside the D1x battery which tells the camera how much " juice " is availdable - sometimes that gets " confused "
Arceye 10 is right. Once the lens is attached to the camera body, make sure that the aperture ring is turned all the way up to the largest number (usually 22). To do this, hold the camera with the lens pointing away from you, and turn the aperture ring clockwise.
Posted on Jan 16, 2009
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
Can't take a picture
Set your aperture to the maximu f stop number, that means the minimum aperture, and your camera will work. Take out the lens and align the ring to set it to the minimum aperture. I shall paste a link down here so that you can refer in detai.
http://loeki.tv/log/archives/85-FEE-error-on-Nikon-DSLR-fixed.html
Dec 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Problems taking pictures on nikon d1x
There may be something wrong with the camera. Make sure it is set to Single Exposure setting and not Multiples. There should be a control on the top left to change this. Look for an "S". this is what you want. If that doesnt help, you may need to get it repaired.
Mar 01, 2009 | Nikon D1X Digital Camera
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
Nikon d1x monitor view problem
either bad lcd or software corruption.
Nov 26, 2017 | Nikon D1X Digital Camera
Washed out pictures
I would check to see if you have set the exposure compensation and/or flash compensation to a high setting and forgot to put it back to zero.
Good luck.
Dec 04, 2007 | Nikon D1X Digital Camera
C-rem
on the nikon support page it gives step by step instructions on how to fix this problem I had that same problem with the Nikon D1, Nikon D1h Nikonusa.com
Oct 26, 2007 | Nikon D1X Digital Camera
Open Questions:
Nikon D1X Digital Camera Logo
333 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
