Question about Kicker IX404 Car Audio Amplifier
Problems turning on
When my car is not started but put on accessories the amp will work and will be playing everything. but when i actually turn my car on the amp turns off and the power light turns from green to orange. the only thing running off the amp are 2 10 inch kick comps
    Problem Solver:
  • 4 Answers
Pull your lead power wire right off the positive term. on your battery
Posted on Dec 31, 2008
03 chev s 10 pickup no start -turn the key get lights stereo fuel pump everything But the starter-have to turn the key back and forth until it finally starts except one time ten minutes of nothing gave up...
I'd start with battery cables. (Hear me out) Lights and other accessories draw minimal amps whereas your starter draws 100s of amps. Your battery cables, especially the bottom ends are exposed to grease and grime which causes resistance. By turning key multiple times you actually heat cables up and they expand making better contact. That would be my first thing to look at. You very well could have bad starter & solenoid but I'd start w/cables. Clean them with a good stiff wire brush.
Feb 25, 2011 | 2000 Chevrolet S-10
I am trying to put a sterio in a mitsubishi varada 98 model and we cant wire it proply
I guess the problem is trying to figure out which one is the power, accessories, ground, speakers, etc.
1. Get a DC tester, the ones which has a bulb on the end. Or a multimeter.
2. Make sure you connect the clamp to ground, usually the door hinges is a good option.
3. Turn everything off, take the keys off.
4. Start testing each of the cables. The one that lights up with everything off is the power.
5. Now tape the power so you don't make contact with metal.
6. Turn the car key to ACC position.
7. Start testing with the DC tester. The one that lights up now is the ACC.
8. Now the negative is usually black.
9. Now you can run new speakers cables from your new radio.
If you are installing an amp, you will just have to run the remote from your new radio to the amp to turn it ON.
The AMP installation is different from the radio.
Hope it helps.
God Bless You!!
Feb 05, 2011 | Car Audio & Video
Rockford p8002 keeps pulseing. (not a ground problem)
for seeing a out of phaze speaker you would have to run like a 10 hz or lower signal to the amp you might be seeing a optical illusion if they were out of phaze or backwards the speaker would have cancled each other out so it would sound like **** as you said.but anyway it sounds like the amps power supply is bad.put it back in you car and see if it still works like it did befor you put it in your friends car.you may have burned it up.find out how much the amp is worth and if can have it fixed for less then 60% of orignal cost then have it fixed
Mar 18, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Bass speaker start up noise
Hello anne845,
It sounds like the installer wired the amp remote turn-on terminal to an "accessory" lead in your vehicle. Many stock radios do not have a dedicated amp turn-or lead and the alternative is to connect the amp to a switched power source (ignition or accessory). This means the amp turns on whenever you turn on the vehicle ignition, often resulting in a thumping from the subs. It is a perfectly satisfactory alternative, and will not damage either the amp or the sub. But it's irritating.
If the thumping is objectionable, have your installer wire a SPST (Single Pole, Single Throw) toggle switch inline with the turn-on wire. The switch should be mounted so it is accessible by the driver, and whenever you turn on the radio, turn on the toggle switch.
Hope this helps.
May 11, 2009 | Alpine SPX-17MB 300 Watts MIDBASS Speaker...
Subwoofer wont play
change your rca's you may have a bad one that is grounding out or one of your spkr
Apr 14, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Have power and accessories until key is turned to start
U will need to replace the ignition switch, this is not the key cylinder but the actual electrical switch the key cylinder operated. see photo. I noted that on your model Honda the switch comes with a new key cylinder, you can just use the switch and use your old cylinder over or install the new parts together.
Apr 08, 2009 | 1997 Honda Civic
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Car amp will turn on but won't play.
Yes your amps output is burned out, you can have them repaired or start looking for new amps
Dec 06, 2008 | Car Audio & Video
Battary goes dead with radio on in 10 min-
if you have your ignition turned on to accessory (just before starting) then you are actually running engine managment computer and more.. this eats up the battery power very quickly on its own. Add a couple of accessories and your radio or cd playing and you are looking at the problem you are having. I'm afraid short of re-wiring your socket so it has power even with ignition key removed there is nothing you can do
Oct 04, 2008 | 2002 GMC Envoy
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Kicker IX404 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
