Question about Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000
Microphone volume on Motorola IHF 1000
When I call people using my IHF 1000 couplew with my Blackberry curve, people think I'm calling from a garbage can.  Any way to make the microphone more sensitive?  Is it an issue with my phone?
    New Friend:
  • 12 Answers
First thing, in your Blackberry's Bluetooth Devices list, find the IHF1000, then go to the Properties for this device. There should be a listing for Echo Cancellation - the choices are Automatic, On or Off. Set this to OFF. The IHF1000 has its own internal noise and echo cancellation - when connected the the IHF1000, your phone's noise and echo canceller should be turned off. This setting change will make sure of that.
Next, how and where is your microphone positioned? If you could post a link to an image I could view of how it is mounted, I can guide you further. Use tinypic<dot>com to post the image, or similar. Ideally, the IHF1000's microphone should be placed on the overhead console or domelight assemmly towards the front of the vehicle. It should be on the side of the console closest to the driver, and aimed at the driver. The cable comes out of the back of the microphone, so as a guide, the cable exit should be on the side of the microphone opposite of the driver.
Posted on Jan 09, 2009
Volume and microphone flucuation
This is a device issue. You will need to contact your service provider for replacement options!
Mar 10, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
Dont hear me!
you may need to have the microphone on the phone replaced but first check when placing a call that the volume is up to all.......
Aug 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Iphone 3G blutooth microphone volume extremely low
go to the volume control for mirophone.
Jul 15, 2009 | Apple iPhone 3G
Won't pair with Motorola HS850 headset
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
People can't hear me on my Blackberry Curve unless I turn the phone and talk loudly right into the speaker. I am so sick of having the "I can't really hear you" conversation! With my bluetooth, I have the...
When using the IHF1000 with your Blackberry Curve, I recommend to go into the device properties for the IHF1000 in the phone's Bluetooth devices listing. Under that, there should be a phone setting to turn Echo Canceller: On, Off, or Automatic. By default, it is Automatic. For this phone with the IHF1000, I would set it to Off. This has solved audio quality problems for a number of people.
Note: this may or may not directly address the low uplink audio level you are experiencing, but it does seem to help with general call audio quality when connected to the IHF1000.
Mar 06, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
How do I pair a black berry 8820 to a motorola ihf-1000 bluetooth
Here is a link that will direct you through the entire process. You will need to select the Blackberry 8830 as your phone, but the instructions should still be the same. Let me know if you need further, and I can give you more.
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=0a50d590556c9010VgnVCM1000008206b00aRCRD
Feb 21, 2009 | RIM BlackBerry 8820 Smartphone
My ringtone volume sounds too low for a blackberry curve.And my friends have the same phone and its louder!Im mad this phone is brand new!!
Just_Bobz is correct and incorrect at the same time...
Not all blackberry curves are set up the same nor do they all have the same "theme" (layout)
For instance the T-mobile Blackberry Curve (8120) has a different theme and therefore the sound option is not in the upper right hand corner like the Alltel Blackberry Curve (8330) default theme.
chrisalexisx
My suggestion is to find the volume control icon on your curve (or the volume themes as I like to call them). When you click on the speaker icon you will have the options for the different volume themes such as Loud, Vibrate, Quiet, Normal, Phone Only, and Off. Click on whichever theme you will be using on a regular basis to activate it.
** Another area where Just_Bobz is incorrect… just because you have put the volume theme on Loud does NOT mean that the phone is on its loudest possible sound setting!!
If you go back into the volume themes, all the way at the bottom there is an Advanced option.. If you click on Advanced, highlight which ever theme says active next to it and click your trackball to open it ... you will then have the option to change the option for any and all alerts on the phone (ie email, phone, mms, sms, bbm. ect.) Under each of the different options there is ANOTHER sound option for low, medium, high, ect. (and there is an in and out of holster setting
SOO..
Just because your volume theme is set to Loud.. does not mean that the phone is truly set to loud!!
Feb 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
MOTOROLA IHF 1000
You need to pair the carkit with your phone. Make sure the Bluetooth feature on your phone is set On, then follow the Pairing process outlined in the user manual.
Jan 02, 2009 | Motorola Mobility Blnc Bluetooth Car Kit...
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000 Logo
264 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
