Question about Magic Chef 9122 Gas Single Oven
Strong Foul smell coming from oven only when I turn it on
I have a tappan oven and it never smells when I use the range. Only when I turn the oven on. It doesn't smell like gas or anything rotting. It smells like a strong chemical of some sort. My carbon monoxide/explosive gas alarm always responds when it is on, so I have to open all of the windows. Also, the flames come up a little into the actual oven space from the broiler. Any idea what it can be?
  • pyrapyt Dec 31, 2008
    We don't have mice. It smells more like soot or something. Just very strong.
  • pyrapyt Jan 01, 2009
    ok....Where is this brass hood/orfice and how do you get to it? So once I find it, turn it down, then openthe air shutter. Where is the air shutter?
    Sergeant:
  • 311 Answers
Do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Posted on Dec 31, 2008
  • Thomas Malailua
    Thomas Malailua Jan 01, 2009
    sorry some how i didnt get all your comments.but now i do.are you propane.there is a brass hood /orfice on the oven gas valve.4 propane that should be turned all the way down and the air shutter should be open all the way.if any of that is so you may need to clean it all up[soot[you dont want any off the holes blocked on the burner by the soot
  • Thomas Malailua
    the oven saftyvalve is towards the bottem of your oven.the burner attaches over it.get down there and take a look.familuirize your self with whats in there then we can talk apples to apples
Burrner's are not working i can smell gas coming out but they wont loght up
you need to light the pilot light or if it is electric pilot replace it
Sep 03, 2012 | Tappan Ovens
A gas smell is coming from the oven but all of the pilots are lit for the burners. The oven wont turn on.
Probably thermocouple needs to be replaced. pay attention to hygiene, KEEP YOUR COOKING APPLIANCE CLEAN and it will serve you reliably for a very long time. Keep it CLEAN and SERVICED and it will serve you for life.
Sep 10, 2011 | Tappan 30IN ELEC IGNa Oven
I have a strong gas smell when I turn on the oven in my GE JGBP28 series range. Have never had a gas stove before. Is this normal?
You ignitor is probably weak. With age they get dim and allow small amounts of gas to escape.
The ignitor should be so bright you cannot look directly at it. How it works:
Aug 23, 2011 | Ovens
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Magic Chef 9122 Gas Single Oven Logo
942 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
