My computer wont read my installation cd for windows 98
My reinstallation cd wont work i have windows 98 somehow i lost everything
  • jp9264 Dec 31, 2008
    not sure if my computer is booting from cd but from c promp im getting a message ( not reading drive a abort,fail ,retry ) what should i do
  • 3 Answers
Are you sure your PC is booting from Cd?
Posted on Dec 31, 2008
  • Gabriel A Perez
    Gabriel A Perez Jan 01, 2009
    To start this Windows install. First check that the first boot
    device in your system BIOS is set to the CD-ROM Drive.
    (The system bios can
    usually be entered on boot, usually by pressing the F1, F2, F8, F10 or DEL key.
    Make sure you save the settings before exiting))
    If you are unsure or don't want to enter the BIOS then just test
    the computer by putting the CD-ROM in the drive and rebooting the computer. This is the recommended way to
    install windows.
    You will know that your computer will/has booted of CD-ROM when
    the following screen appears.
After I re-installed windows 98 my EZCD creator 5.1 says that there are no supported CD recorders available. I somehow got it working once but then had to do a system restore and lost it again. So I know...
Try reinstalling the device drivers in Device manager. Right click my computer and select properties then hit the hardware tab then the device manager button. You should find your drivers under the cd/dvd-rom heading. If you don't have the cd any more try to go to the manufacturers web site.
Mar 21, 2011 | Philips Computers & Internet
My latitude d600 wont start up!
hi, your windows explorer is corrupted. to solve this, simply insert the xp installation cd and boot from it. then run repair to fix the os. note your files will not be lost
Jan 24, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Cd rom will not read. have just put windows 98 on instead of xp, hard disc was formated, have win 98 now, but cd wont work or if i plug in usb memory stick
With Windows 98 you MUST install a suitable driver in addition to Windows 98 to talk to CD Roms. I believe there is also a general service routine that must be loaded.
XP has all this functionality built in.
Try this site to solve your problem:
http://www.computerhope.com/download/hardware.htm
Nov 07, 2009 | Acer Aspire One PC Notebook
Corrupt program in windows 98 , disc can't read to reinstall again
change Windows98 cd., or if you had dump in the partition try to install from there., some scrtaches on the cd., certain files wont read, better to change the new Cd, it works
Mar 27, 2009 | Microsoft Windows 98 for PC
HP 5150 PRINTER SOFTWARE AND DRIVERS FOR WINDOWS 98
plz check the website for the driver for win 98
Oct 28, 2008 | HP Office Equipment & Supplies
HP L7680 All in one will not send faxes from PC S/W interface
After much thrashing, here is the solution to the problem. Somehow the printer drivers lost coordination with the corresponding Windows supporting programs. You would think that reinstalling the printer drivers would fix the problem, AND IT DOES, but there are 3 tricks:
· Uninstall everything associated with this printer with the install disk in the computer (this may really not be necessary, but it worked for me). [This is also the solution when the a window comes up asking for TrayApp to be inserted using a disk—they mean the hp install disk].
· After the un-install, MAKE SURE you ALSO delete the printer using the control panel. This is critical. If this doesn’t happen, the corresponding Windows software is somehow hooked to the wrong thing when the reinstall happens. Then reboot the system.
· Install the new drivers with the printer off, and the USB disconnected from the printer. Reboot the system [not sure the reboot is necessary]. After the computer has booted, connect the USB, and power up the printer. The computer will recognize the printer and put the printer icon in the Control Panel.
It turns out that correcting the driver mis-coordination by BOTH uninstalling the printer drivers and taking the printer out of the control panel, then properly reinstalling solves BOTH the fax problem, and the protection fault problem! Amazing such a little thing can make such a difference!
Jan 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Windows 98 Install on Dual Machine?
del higher uper lower strings in regisrty microsoft has fix for this on site type cd dispers in my computer i had the link but lost my faverties its the upper and lower control filters in registry u need to del ok
Jan 19, 2008 | Microsoft Windows 98 for PC
Windows 98 install
It could be a memory related problem. Try to test your memory module by installing it to a different system that is surely working. If that system restarts, then you must replace the memory module.
Nov 20, 2007 | Microsoft Windows 98 for PC
Have Windows 98 no keycode on computer that had been overwritten with linux
A Google search may help but unfortunately we can't give any keys out on here. Its against the rules.
Nov 03, 2007 | Microsoft Windows 98 for PC
Loading software caused hanging on startup
May be your windows 98 is damaged and need to be re-installed. Even if you reinstall windows 98, there are more chances of your getting your documents back. I meant to say that just reinstall and to not format. you may get your windows running again. You should have your windows 98 installed with DirectX 9.0C and internet explorer 6.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
