Question about Maytag Washing Machines
Washer stopped running
Was washing a load of clothes and stopped running before the rinse cyle
will not turn on at all
    Genius:
  • 2,920 Answers
Check the pump on the machine if its clogged it wont let the washer drain
Posted on Dec 31, 2008
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
The rinse cycle does not work, but everything else does
I don't know if the problem is solved but last night we ran the washer without any clothes in it and everything seemed to work fine. My wife was able to run a load of laundry and it seemed to work. I hope it was just too much clothes the first time it stopped or the washer was just acting up. Either way, I had nothing to do with the fix. Sorry I couldn't be any more help. Thank you for the link to assistance plan, it might come in handy in the future.
Thanks again,
Sandro Micocci
Mar 30, 2009 | Kenmore Washing Machines
The washer is no longer going through the rinse cyle
Check the timer, which is behind the knobs, and check also the power supply. If both work, then move ontothe relay, if still no avail go to the computer board
Feb 09, 2009 | Amana ALW880WH Top Load Washer
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
