Question about Kenmore 24032\24036 Top Load Washer
My kenmoe washer starts filling up with water but won't fill up. Water is just keeps running through but won't hold the water.
  • 135 Answers
You drain hose must be higher than the tub. you can solve this with a standpipe or a siphon break kit.
Posted on Dec 31, 2008
WASHER WON'T FILL WATER
Check to be sure the drain line is higher that the tub of the washer. You have a siphon going on the drain.
Nov 05, 2012 | Hotpoint Washing Machines
Washer over fills with water
They work on a pressure switch. It has a rubber hose that connects to the bottom of the drum and runs up to the top control panel. When water fills up into the hose the air pressure trips a switch. So either the switch is bad and not making contact when it clicks. Or the hose is leaking air so it won't let it build up enough pressure. I had one that a mouse got up into and chewed a hole in the hose. You can take the back panel off of the top control panel and let the water in and listen to see if the switch clicks when it gets fulll. If it does and doesn't stop filling then it is a switch.
Or it could be the water shutoff switch where the water hoses hook up. If it is that then it will run all the time, more than likely. Is that what it is doing? Does the washer start running and water keeps coming in? Because it wont start running until the pressure switch is enganged. If it starts running and keeps coming in it is that. Good luck hope this helps.
Dec 04, 2011 | Kenmore 24032\24036 Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Automatic bleach dispenser fills up with water during fill cycle
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 04, 2009 | Washing Machines
Water keeps running
missmelissa, sounds like you are siphoning. Lift the drain hose from the drain and see if it fills then. You need to have a air gap on the drain so you don't get the siphoning affect. Catriver..post back.
Feb 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Robert Rankin
