Question about Mitsubishi HS-U795 S-VHS VCR
The sound cuts on and off and on and off and...
The audio on my MITSUBISHI HS-U795 will cut out for about 15 or 20 seconds and then come back on for a minute or two then cut out again......and on again...and off again etc. We can rule out tracking problems because this occurs whether there's a tape loaded or not. I've checked and even replaced the audio cables so I know that's not the problem. The same problem occurs when I'm playing a tape as well.
    Novelist:
    Champion:
  • 254 Answers
First, have you definitely ruled out an external problem, by hooking it up to a different television or audio amp? If the problem follows the VCR to whatever it is hooked up to, then obviously, the VCR has a problem. Likely, this is an internal electronic defect. Services of a repair shop would be required. Sorry I can't be of more help.
Posted on May 07, 2007
Mitsubishi receivers
sounds like an overheating thermistor - how long between restarts?
Nov 26, 2013 | Mitsubishi Televison & Video
Genius HS-03U Volume Control Help
It's not fixable.
Set as default audio unit to "USB audio device", because Genius HS-03U control the volume only sound device by default.
Headphones improperly trying to adjust the volume of "alien" audio devices, such as second sound card, if it is selected as the audio output device by default.
Oct 20, 2009 | Genius HS-03U Headset
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
Mitsubishi HS-U680 VCR
Here are the possibilities:
1. really dirty heads - both video and audio
2. TV is not selecting the right input for the VCR.
3. difficult (but rare) failure in the VCR output circuitry.
Hope Ya Fix it!
Jan 22, 2008 | Mitsubishi HS-U680 VHS VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Mitsubishi HS-U795 S-VHS VCR Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
