Question about HP Pavilion zd8000 Notebook
Cant boot my computer
Computer wont start with a disk or anything tryed resetting bios i keep getting a wireless adapter conflict error
How can i boot or restore from bios screen i keep getting error code 0xc000000d
Try going to one of the bios settings that offer a choice different from the present setting but would be equally ok or doesn't matter and make it change to the new setting - then go to the exit or whatever to confirm the change and press enter. The cpt should then boot up. If not keep reading all of the printed entries available in the bios (including bios reset or bios update) and go with one of them. There also should be a bios disconnect lead on the mboard which can reset the bios - be a bit careful with that choice..
May 24, 2014 | Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
Boot up error
You may have to open your computer and locate the hard drive. Trace the cable to see where it plugs into the motherboard. If there are other slots that it will plug into the motherboard, try plugging the hard drive into those.
If you have SATA plugins, it will be relatively easy to find a new port to plug it into. If you have IDE plugins, you may want to skip my solution and try other things first.
Apr 16, 2009 | Computers & Internet
I have just purchased a netgear MA111 wireless adapter, for my desktop pc, which is running xp, the problem i have is that everytime i plug in the adapter, the computer restarts, if i disconnect the...
Hello annwiles,
Checking IRQ Conflict in Windows 2000 or XP:
1. Click on the Start button, and click on the Run option.
2. When the Run window opens, please type in devmgmt.msc and click OK.
3. When the Device Manager Window opens, click the View menu. Then, select Resources by Connection.
4. Expand the Interrupt Request (IRQ) category to view IRQ assignments.
5. Once you find your adapter on the list, check if the number that is assigned to it is the same as anything else on the list.
6. If your adapter is sharing an IRQ with another device, you may be having an IRQ conflict.
Resolving the IRQ Conflict:
1. Try placing the Network Adapter into different PCI slots. By doing this, the BIOS will assign the network adapter a different IRQ.
2. Disabling COM and parallel ports, or built in motherboard devices (sound chips, etc) in the BIOS may help to free up their IRQ's.
Note: Changes to the BIOS can cause major problems with your computer. If you are unsure, please contact the manufacturer of the PC for further assistance.
3. You may be able to assign IRQ's by PCI slot in the BIOS. Please contact your computer manufacturer for more information.
Apr 09, 2009 | NetGear MA111 802.11b Wireless USB Adapter...
Inspiron 1521 won't boot up. Get read disk error.
hello!!
put ur OS cd and enter repair console and try fixboot command!!!
Mar 23, 2009 | Dell Inspiron 1521 Notebook
Win XO Pro displays MSG: "IRQL_NOT LESS OR EQUAL" on blue screen. Sounds like a hardware compatibility problem with SMCWPCI-G2 wireless card adapater. Any hints on how to solve this?
This almost always seems to be an IRQ conflict that the BIOS can't resolve with its plug n pray skills. When this conflict is passed to XP at boot-up time, XP panics and blasts you with this error message.
Before you start pulling cards, go about pulling cards, go into the BIOS and change the IRQ of the on-board compnents, if you can, and also disable any on-board components that are not needed. (such as the parallel port, on-board ethernet connection, etc.)
Mar 05, 2009 | SMC EZ Connect g SMCWPCI-G (SMCWPCIG)...
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Windows will not boot
Just turn-off network boot in your bios
Nov 15, 2007 | Acer Aspire 5100 Notebook
Bios Updater Dont work
well dint get ya point but i found dis bios updater for u http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5V-VM-DH-BIOS-0909.shtml check it out it myt b helpful to n another thing is that r u using 3 of ur pc's @ one time when u using internet
if yes then ur ip myt b conflicting 1st of all bring some technician to ur home so that he can fix ur wireless stuff it myt be the problem i guess its not configured correctly so do it!
Oct 19, 2007 | ASUS P5VD2-MX SE Motherboard
Boot
CORRUPTED BIOS Reprogramming the BIOS That depends on your motherboard Model. It should correspond to your BIOS Model. Download the Motherboard's BIOS file usually in a Zip file then the contents are .bin files. Then use the BIOS manufacturer's EPROM Programming tool. Which usually comes with a user manual or guide on how to's. Just follow its examples. Hope this helps ======================= If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 21, 2007 | Intel DG965WH Motherboard
HP Pavilion zd8000 Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
