Question about Dometic Rooftop RV Air Conditioner
Neither Roof Air Works
2007 Mandalay Presidio. Have two 13,500 roof units 620525. Just got back from a trip where we did not use roof air and experienced freezing temps a couple of times. Back in Florida I discovered the neither unit will cool. They will blow warm air for about a minute and shut off. Is there a freeze reset?
    Problem Solver:
  • 7 Answers
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Posted on Jan 03, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I have a 13,500 Dometic A/C that usually blows cool air but sometimes changes sounds and blows hot air for a while before switching back to cold. What do I need to fix?
Could be the compressor overload on the way out. Or an intermittant temp control. Or it might just be a loose connection at the junction box between the roof and the base.
May 04, 2010 | Dometic Rooftop RV Air Conditioner
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Jun 29, 2008 | Coleman Mach III Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
101 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
