Even though my options setting says "Double-click to open an item (single-click to select)", things are getting selected when the cursor is merely poised over them without any clicking. Often this means an email or a program is opened without me wanting it to be, or it may mean when I start typing the location where the type is inserted is not where I had clicked but instead where the cursor had moved to in the meanwhile.
  • 2 more comments
  • datagogo Jan 05, 2009
    Thank you so much for your suggestion. I tried it but it didn't make a difference. Please let me know if you have any other ideas, because this problem is happening in every application I use, including Internet Explorer, Microsoft Office, and even just navigating around my file directories.
  • datagogo Jan 07, 2009
    Thank you. I went to the Ease of Access Center and the "Activate a window by hovering etc." box wasn't checked. I tried checking it, rebooting and using the computer for a bit, then unchecking it and rebooting again, but I'm stilll having the problem. I can't change the mouse as I have a laptop with a touch pad (or can I change the touch pad? and if so, should I?). Anyway, my laptop came with Vista pre-installed, so the only way I can reinstall it is from my Vaio recovery disks that I made when I got the computer. Will this mean reinstalling all my other software? It is such a pain because I use a lot of programs and I don't have all of the activation/registration codes easily accessible. Do you think there's a Vista update that will fix this? Anyway, thanks for your help.
    So, I tried looking around the Internet for answers and I found the following info, but I don't know how to do what it says to do. Can someone interpret this for me? I tried typing the text into both the "Run" box and the Command prompt and neither worked. I am not a power user and don't know what to do next:
    "Use the following command to find the correct handler of the Alps touchpad:
    cat /proc/bus/input/devices
    on my system, it shows up something like the following
    I: Bus=0011 Vendor=0002 Product=0008 Version=7321
    N: Name="AlpsPS/2 ALPS GlidePoint"
    P: Phys=isa0060/serio1/input0
    H: Handlers=mouse3 event5 ts2
    B: EV=f
    B: KEY=420 0 70000 0 0 0 0 0 0 0 0
    B: REL=3
    B: ABS=1000003
    Then, modify the /etc/X11/xorg.conf file, the tricky part is the "Device" and "Protocol" parameters. Use the above output (in my case, event5) as the value for "Device", and "event" as the value for "Protocol". Saved the file, restart and the Alps on Sony works again.
    The following is my xorg.conf:
    Section "InputDevice"
    Identifier "Configured Mouse"
    Driver "mouse"
    Option "CorePointer"
    Option "Device" "/dev/input/mice"
    Option "Protocol" "ImPS/2"
    Option "Emulate3Buttons" "true"
    Option "ZAxisMapping" "4 5"
    Identifier "ALPS"
    Driver "synaptics"
    Option "AlwaysCore"
    Option "Device" "/dev/input/event5"
    Option "Protocol" "event"
    Option "LeftEdge" "120"
    Option "RightEdge" "830"
    Option "TopEdge" "120"
    Option "BottomEdge" "650"
    Option "FingerLow" "14"
    Option "FingerHigh" "15"
    Option "MaxTapTime" "180"
    Option "MaxTapMove" "110"
    Option "ClickTime" "0"
    Option "EmulateMidButtonTime" "75"
    Option "VertScrollDelta" "10"
    Option "HorizScrollDelta" "0"
    Option "MinSpeed" "0.45"
    Option "MaxSpeed" "0.75"
    Option "AccelFactor" "0.020"
    Option "EdgeMotionMinSpeed" "200"
    Option "EdgeMotionMaxSpeed" "200"
    Option "UpDownScrolling" "1"
    Option "CircularScrolling" "0"
    Option "CircScrollDelta" "0.1"
    Option "CircScrollTrigger" "2"
    Option "SHMConfig" "true"
    Section "ServerLayout"
    Identifier "Default Layout"
    Screen "Default Screen"
    InputDevice "Generic Keyboard"
    InputDevice "Configured Mouse"
    InputDevice "ALPS"
  • datagogo Jan 16, 2009
    Although the link you provided didn't lead me to the right touchpad driver, I was able to find out which driver I needed by checking my hardware configuration (Alps touchpad driver), and while there wasn't a new version, I reinstalled the existing version and it appears the problem is fixed. Thanks so much!!!
    Problem Solver:
  • 14 Answers
Try to restore defaults
Posted on Dec 31, 2008
  • 1 more comment
  • pas_sal1990 Jan 05, 2009
    if you are using vista then this may help:
    "Control Panel
    -> Ease of Access Center
    -> "Make the mouse easier to use"
    -> uncheck the "Activate a window by hovering over it with the mouse" checkbox."
    If it still occurs then try changing mouse, if still the same i think you are going to have to reinstall windows
  • pas_sal1990 Jan 07, 2009
    Ok since you have a touchpad its probably made by a companie called synaptics.Try reinstalling the software of it.
    Another thing try to disable the touch pad (there may be a button that does that on the laptop) and plug in a usb mouse and see if you get the same result.
    Dont change the touchpad if you are not sure that its the problem
    Looks like Linux Touchpad Driver, useless in windows
    this is the driver you need for your viao touchpad,
    might not be the same model but its the same touchtap
    if you want to be sure lookup your laptop model on the sony esupport website
How to Open Files and Folders in Single Click?
Go to pointer settings an search for click options
Oct 18, 2016 | Computers & Internet
Cannot create folder
Use Windows Explorer to open the folder in which you wish to create the new folder.
The "My Documents" folder is a good choice if you are new to Windows.
Look at the left side of the Explorer Window for an area marked "File and Folder Tasks."
Click on the link that says "Make a new folder."
Click on "File" on the menu bar to begin creating a new folder in a different way.
Select the "New" menu item and click on the "Folder" submenu item.
Move the mouse cursor to a blank area of the folder area and right click to bring up the context menu to begin creating a new folder in a third way.
Select "New" and click on the "Folder" submenu item.
Utilize a fourth method to create a folder directly on the desktop.
Right click on a blank area of the desktop.
Type a name for the new folder in the highlighted area after using any of the methods described in Steps 2 through 4.
Press the "Enter" key or click in a blank area of the folder window to complete the process.
also you might just open your drive right click inside select new folder and name it.
Restore Folder Options in Windows XP
Windows XP has several viewing options that you can modify for folders in Windows Explorer. These include being able to customize whether you activate items by clicking them once or twice, whether Windows displays hidden and protected files and several other options.
If you have played with these options in an attempt to determine how you prefer to use your computer, you may accidentally reach the point where you have changed so many items that you are unsure of how to revert to the original configuration.
For this reason, Windows XP allows you to restore the folder options to their defaults by clicking a button.
Open Windows Explorer.
Two of the fastest ways to do this are by clicking the "Start" button and then clicking "My Computer" and by double clicking the "My Computer" icon on the desktop.
Click the "Tools" drop-down menu and select "Folder Options."
Click the "General" tab, and then click the "Restore Defaults" button if you would like to restore the default settings for the "Common Tasks" bar on the left side of folders, whether new folders open in the same window or a new window and whether items open with a single click or double click.
Click the "View" tab, and then click the "Restore Defaults" button if you would like to restore any advanced view settings to their defaults, such as whether Windows displays hidden and protected files.
Click the "Reset All Folders" button if you would like to restore the default viewing option to all folders, such as the detailed view or list view.
Click "OK" to save your changes.
Aug 14, 2013 | Western Digital Passport Computers &...
Mouse double clicks by itself
Check software settings, Assuming OS is windows. Open "my computer" select "Tools" from the top menu and "folder options". In the General tab select "single click to open an item" from "Click Items as follows"
Jan 15, 2011 | Logitech MX1000 Laser Cordless...
Clicks are very fast and difficult to select something without it opens
Assuming you have a PC, go to control panel, click on mouse and there you can set the click speed for double clicks. Another way to prevent this is to go to folder options and tick the button for 'single click to open item - point to select' That way you highlight (select) an item by just moving your mouse onto it and open it by only clicking once. Hope that helps
Jul 24, 2010 | IBM Lenovo Mouse 76H6618
How can i set my laptop cursor to open a file by double clicking?my laptop cursor is moving but it cant open a file, or its not working when i click the file to open.
Try going to start, control panel, Hardware, then Mouse and check your settings. Make sure the double clicking speed isn't set extremely high.
Mar 01, 2010 | Toshiba Satellite A135-S2276 Notebook
How can I turn off the keyboards
at first go to my computer..then in the meny option (where file , edit, view, toll is located), click the tools button and click on folder option. a dialogue box will appear then. in the dialogue box, go to the general tab and point to the 3rd option "click items as follows" and then select single click to open a file..
thank you
don't forget to give feedback and ratings
Feb 04, 2010 | Compaq tc4400 Tablet PC (RL875AW#ABA)
I have to double click the left button to select items on a web page rather than a single click. how do I fix?
Change the number of mouse clicks required to open items To change the number of mouse clicks required to open items
  1. Open Folder Options in Control Panel.
    • Click Start, and then click Control Panel.
    • Click Appearance and Themes, and then click Folder Options.
  2. On the General tab, under Click items as follows, click the option you want.
  • If you click Single-click to open an item (point to select), you can also specify when icon titles are underlined.
  • To check your current browser settings for underlining links, open Internet Options in Control Panel. To open Internet Options, click Start, click Control Panel, click Network and Internet Connections, and then click Internet Options. On the Advanced tab, check the setting for Underline links.
Jan 06, 2010 | Microsoft Wireless Laser Mouse 5000
When using the touchpad the cursor always double clicks
For that go to start menu->control panel->folder optitions.
Then you can see first general tab settings.
Make sure in "clci kitems as follows" the option button for "double click to open item " is enable.
Then apply and ok.
If still face same issue then uninstall touchpad driver and reinstall driver again then it works fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 22, 2009 | Samsung NC10-14GW PC Notebook
How do i not have my pointer automatically click on a item?
Thank you for using
FixYa for your problem
Click start > my computer > tools > Folder options > general tab > click items as follows section > select the radio button for the option "Double-click to open an item (single click to select)"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Computers & Internet
Mouse double clicking when I press the button once
recheck your computer for viruses again and reinstall the driver for your mouse it should work
Nov 07, 2009 | Razer RZ01050300 Mouse
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
