Question about Microsoft Zune JS8-00001 Digital Media Player
Freezing My first generation Zune worked fine fore about 2 years, but it has been freezing more and more. Now it is currently frozen on the turn on screen, and will not un freeze no matter what I do
  • dancsontos Dec 31, 2008
    My zune starts up and the white bar loads all the way and then nothing at all. Just permanently stuck. Reset doesn't work, plugging it in to usb cable does nothing! HELP!
  • 3 Answers
See teh site The 30 Gig Zunes have a bug in how it processes the date. Per MS it will fix its self 1 Jan 2009
Posted on Dec 31, 2008
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune freezes
Have you tried a hard reset? You can do this by pressing and holding the back button and the top part of the zune pad at the same time until the zune restarts.
If you can get the zune restarted you might want to check for firmware updates or try reinstalling firmware. If you are still having issues and the Zune is less than a year old it may be easiest to just send it of to Microsoft.
Jan 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune locked
Go look on and then click support. My zune just did the same thing a little bit earlier and I was worried so I went looking on the net and found these entries. Under support it says:
My Zune 30 is frozen on the boot screen, now what do I do?
You will need to reboot your device after noon GMT (that's 7 a.m. Eastern or 4 a.m. Pacific time) on Jan 1, 2009.
Please unplug your Zune (no AC or USB cables).
Because your Zune is frozen your device battery will begin draining, this is good.
The battery will eventually be fully depleted and the screen will go black.
After noon GMT on January 1 connect your AC power or USB cable such that the battery can begin charging again.
Once the Zune has enough battery to boot it should do so normally and you can go back to enjoying your Zune!
My Zune 30 has been working fine today, should I be worried?
Nope, your device is fine and will continue to work as long as you do not plug it into the PC before tomorrow.
If you plug your device into a PC before noon GMT Jan 1, 2009 your device clock will be set to the last day of the leap year and you will experience the freeze issue. If this happens, see above.
The PC that you plug into does not have to have the Zune software installed in order for your device clock to be set and the leap year bug to occur so you should avoid plugging your Zune 30 into any PC today.
What if I have DRM content on my Zune?
Your DRM content will most likely not be affected by this issue. However, it is a good idea to sync your device with your PC once the freeze has been resolved in order to ensure that all of your licenses are up to date.
What if I took the advice on the forums and hard reset my device by disconnecting the battery?
This is not a good idea and we do not recommend opening your device up yourself. However, if you already did it…
If you have DRM content on your device, your DRM store is now out of sync with your secure clock.
You will need to wait 24 hours from the time that you reset the device and then resync your DRM licenses from your PC.
Alternatively you can format your device and resync the content.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
30 gig zune frozen on "ZUne screen"
if u want to fix ur frozen zune take it apart
u will need a razor and a few mini screw drivers
take it apart and remove then reinstall the battery
it should work fine after that
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Theres a note on the zune website about this issue today... Looks like its microsofts fault! At least I feel better knowing I didn't break my zune!
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Zune 80 gig will not start
My 80 Zune has a frozen screen as well... This is ludicrous! Well this is how this problem should be resolved:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
I cannot believe the savvy programmers for Zune did not identify this problem in advance... Well I guess we are all human lol... Can't wait to begin listening to my music again!
Have a Happy New Year!
Dec 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune
If it freezes up hold the pause button and turn it off, then hold down the back button and up on the keypad and it will restart. If for some reason it keeps freezing constantly I suggest you contact zune.
Oct 26, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune keeps freezing up...
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
After charging it froze up!
I have the same problem, it is completely frozen and will not turn on or off even after I charge it. It appears to be completley frozem, help!
Aug 29, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
263 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
