Question about Electrical Supplies
ENGINE QUIT RUNNING GOOD ENGING CHANGED SOUND FOR A FEW MINUTES AND DIED. NO SPARK FROM COIL. FULLOF OIL. DISCONNECTED OIL SHUT DOWN . NO HELP.
  • JOJKING Jan 11, 2009
    MCCULLOCH 13 HP 5700 WATT GENERATOR
    MODEL FG6000MK
    SERIAL JF182FPH0508040729
  • 54generator
    54generator May 11, 2010
    Send me the manufacturer and model number.
SOURCE: 2001 PT Cruiser quit running driving down highway
I HAD THE SAME PROBLEM, I BROKE A TIMING BELT.   HAD TO REPLACE THE ENGINE.
Posted on Mar 22, 2009
  • 4 Answers
SOURCE: eng. shakes spits/sputters oil in spark plugs
I just had this fixed on my suby today. The cause is that the spark plugs, go through the valve covers on the 2.5 l .When the o rings in the cover go, the result is oil in the spark plugs. The cost of the repair in Canada was about $500 including diagnostics as well as new plugs and wires About 1.5 hours labor and new seals and gaskets. It now runs like new. This is a common problem for this subaru engine as well as for the dodge neon.
Posted on May 23, 2009
  • 14 Answers
SOURCE: engine died & wont start no spark ignition coil tested good
try your ignition module in the distributor much more likely. just install rebuilt distributor if that is the problem , if you just replace module the main distributor assem will **** out shortly after.
Make sure you check for broken timing belt also it is one of those two!
Posted on May 27, 2009
  • 12 Answers
SOURCE: 98 Honda Valkyrie Tourer, engine stalls
Check vacuum line from #6 intake runner (port side rear cylinder) to the fuel petcock valve. The valve is vacuum operated for safety. It cuts off fuel to the carbs when the engine is shutdown. Hose could be cracked or diaphram in valve is cracked. Easy to inspect the valve.
Posted on Jun 07, 2009
bargainbin2
  • 123 Answers
SOURCE: Kohler cv15 no spark at the plug.
If you disconnected the stop wire it is a coil ground wire and still cannot get a spark to the head at about 1/4 inch from the head the coil is bad. The only other thing could be a broken or loose magnet under the flywheel but that is very very rare.
Posted on Aug 29, 2009
Truck won't start
If by your description I'm assuming you say "NO START" you mean it cranks but don't start..? Depending on the YR, make & model Poss. defective module? or switch itself, pickup (if app) Wrong plugs, mass air flow sensor (if app) Any C/E LTS? Scan PCM , also ck coolant system readings & ck emissions when running., crank & cam sensors are popular for that problem along with the module and pickup coil too. It's Long list but I would start with a scan of the PCM & check those crank & cam sensors 1st. Good Luck
Nov 26, 2015 | Cars & Trucks
After running, when shut down for just a few minutes, won't start. Has to sit and get cold in ordrer to start.
Check for spark when this happens. What I suspect is a failing ignition coil due thermal breakdown. I have had mowers run an hour or so to quit firing after taking a short nature break.
Mar 20, 2015 | Garden
99 bear tracker
ok did you check for a good engine ground
Jun 09, 2014 | ATVs
My 2001 Monte Carlo ss won't stay running
I would need more information to give you a good answer. I need to know how long will it stay running a few seconds an hour what is it. I had a 2000 blazer that would start fine everyday and i would 10 minutes and it died sometimes i drove an hour and it died. I parked it and everytime i started it would run about 10-15 minutes and die. after it would die i would check fuel pressure which was good and spark. Well turns out there's no spark so i changed coil ,plugs, wires, rotor. I finally changed the crankshaft positioning sensor and that tuned out to be the problem so good luck.
Apr 18, 2014 | 2001 Chevrolet Monte Carlo
Briggs ans Stratton Quantum 5.5 HP still no spark after changing coil and plug
You are correct, you have a flywheel with magnets in, an electronic ignition unit which when the magnets pass the ignition unit core at speed energises and creates a spark via the plug, the earth wire simply takes the unit to ground and shuts off the spark, the unit you changed was it definetly an electronic unit or just a coil? if electronic and you are cranking the engine fast enough and have the plug well earted against the cylinder with the earth wire not connected it should spark.
Sep 01, 2012 | Garden
Engine quit while running and now no spark.
Does the flywheel magnet still have a strong pull on it?
Mar 20, 2017 | Coleman Powermate Portable Generator...
No spark
Here are a few pointers from a former pressure pump tech. Usually no spark is caused by the low oil safety system or spark plug wire shorted. This system will prevent the engine from starting if the oil is dirty or contaminated with gas. Try disconnecting the oil sensor and the kill wire from the coil. If no joy re-install the old coil and test without oil sensor connected. The spark coil can be tested with a growler used to test armatures. Sometimes a shorting sparkplug wire can be found by pulling the starter rope in a dark room and look for sparks jumping to metal. enjoy
Nov 23, 2008 | Garden
My sons 1990 626 ran great. I change the oil and reconnected the speedometer cable that had vibrated loose. took it for a drive to make sure I didn't have any oil leaks. It ran for about 5 minutes and just...
we'll assume fuel is good..leaving spark and air..and management of systems(computer /sensors)...so the speedo cable was disconnected? try taking it loose again , test drive and report back please
Nov 20, 2008 | Mazda 626 Cars & Trucks
Electrical Supplies Logo
66 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
