Question about Jenn-Air Grilling
Ignitor switch has stop working
Please tell me what to check and look for
  • 135 Answers
I had this happen on mine, ane there was a battery in it which was dead! Look around for that. Otherwise the igniter is also replaceable. Hope this helps!
Posted on Jan 01, 2009
Ignitor does not glow.
Normally a dryer will come on and then go out due to insufficient air flow. I your case, you say the igniter never comes on. This tells me that the thermistor is probably OPEN. With a cold dryer, the thermistor should close the contact and allow the relay to pull in. If you have poor air flow, the thermistor will heat and then break the circuit and stop the igniter from working.
Sep 07, 2014 | Frigidaire GLGQ2152ES Gas Gallery Dryer...
Furnace was working fine and just stopped working...it reacts to raising the thermostat but doesnt actually flame on
This is probably a ignitor.
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Please leave feedback... Thanks...
Jan 28, 2011 | Goodman GMS90703BXA Heater
Goodman furnace ignitor works, blower starts up but no flame, no heat ignitor glows then everything stops
sounds more like a pressure switch problem. If the pressure switch does not make, then the furnace will not attempt to light. Its a safety feature on residential furnaces.
Check the pressure switch and hose for obstructions. Clear any and attempt to re-light. If still not successful, its time to contact a local service company to check the gas valves and electronics.
Apr 27, 2010 | Goodman GMS90703BXA Heater
Glo plug/ignitor will not light
I went on other web sights and found some helpfull information that was able to direct me to locate the source of the problem.
Jan 29, 2009 | Whirlpool Dryers
Furnace stopped working.
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Jan 04, 2009 | Carrier Heating & Cooling
GE Spectra stove, oven won't light
Hi ewood,
You can look up your ge owners manual at ge.com . If the oven has stopped working chances are you have a bad ignitor. the part number is WB2X9154 . The part is $69.99 and I have this item in stock. Shipping will be $6.50 in the continental US>
I hope this will FixYa. If you have more questions please let me know. I can tell you how to remove the old ignitor if needed.
Anderson Appliance
Mike Anderson (Owner)
(865)945-3808
Sep 30, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryer not heating up
remove the back panel and check the thermal fuse ( its white maybe 2inches by half inch 2wires leading to it. the most common problem. if thats good( a continuity test will tell,you want continuity thorugh the fuse).then i would check the ignitor assy.that s check also with continuity test, you can also checkt he plug leading to the ignitor for 110v, ifyou got powerr there and ignotir doesnt light you will need ignitor
Mar 13, 2008 | Dryers
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
Grilling Logo
182 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
