Question about GE Zoneline AZ55H07D Air Conditioner
What to buy?
Sun room with 4 inch wall - do through wall units work? of should we get motel type?
  • David Robinson May 11, 2010
    Hello, let's see what you need.
    How big is the room? Give me the length the width and the celing height. Also what is the climate like where you live?
    Problem Solver:
  • 13 Answers
There are units on the market that will work great, one is called a Mr, Slim, look it up on the internet and find a dealer in your area that carries them and check them out.
Posted on Dec 31, 2008
Motel tv broken trying to hook up my own
1st I hope the motel is giving you a discount for a room with no tv , second an educated guess would be that your tv is non digital and is set to receive an antenna signal , along about three years ago most all cable systems went to a digital system , this required a down converter for the older TV's to still be able to work on higher channels but some systems still sent 2-13 out on the wire for the older sets as well , essentially the converter takes a hi res digital signal and changes it to a fuzzy/blurry analog signal for the old tv's , silly as it sounds , there's millions of em working everyday in America that way
Feb 26, 2016 | Panasonic Televison & Video
I have just brought a older style lie Down sunbed! My thing is the bottom section works fine ! But the top one as soon as I plug in the plug it trips the switch
Some of these units use more than 10amps [2400watts at 240volts 1100watts at 110volts] AND will cause the fuse to blow/or circuit breaker tripping every time on a normal wall outlet/circuit.
Best option is to get your local ELECTRICIAN to run a "DEDICATED" 15amp [or larger] CIRCUIT and wall outlet in the room where your Sun Bed is installed ...
The electrical amperage requirement for your unit should be found on the manufacturer's Compliance Plate [on your unit] ...
ALSO it is possible that there may be a FAULT in the top unit [sometimes caused by a damaged supply cable on the older type "CLAM-SHELL" units] ...
Probably best to have it CHECKED/TESTED by your local Electrician.
Sep 20, 2014 | Health & Beauty
My 2000 Winnebago Journey 36L TrueAir A/c will trip electric breaker when outside is 85 degrees. Generatror will only use 12amps(not enough to cool coach). and stop.
you didn`t told the ampere of your unit,but any way,we are using 25 amperes for 18000 btu on split and room type.try to make a 4 by 4 feet cage with sidings and roof and ventillated holes on all sides of walls.and the front leave it uncovered.that is for split type.if for room type only,make a longer roof for it
Apr 17, 2014 | Coleman Heating & Cooling
Amana pth153a35ac
The first 3 answers were from idiots. If a person had read her problem they would understand that it is not a oven / stove, but a PTAC unit that heats and cools a room. This type of unit is what is commonly seen in hotels and motels where the individual heating / cooling system is in each room.
Nov 29, 2013 | Ovens
What rules should obey about position where to hanging murals?
Generally, do not recommend to put murals entire room wall that will make the space without focus. You can choose the side of the main wall, put a large mural. The hand-made wall art as faces of home decorations often giving people a large visual impact, the effect is very prominent and impressed. Another way is for some special space with targeted put murals, such as the sun room with mural theme of the sun, flowers and birds or big tree in the stairwell. There is also a type dotting corner location, like a switch seats, air conditioning pipe already have pattern of flowers, natural leaves, the wall you can match with murals, it can often bring unexpected effect.
Dec 27, 2012 | Cell Phones
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
I have an LG wall unit in my sun room. Geicos are coming into the room through the unit. Do you have a screen I can use to keep the Geicos out??
At a hardware store ask for 1/4"bird screen to fashon a cover.It wont block air flow that the unit needs & keep the pests out.
Mar 18, 2010 | Heating & Cooling
How large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Jul 21, 2008 | Heating & Cooling
GE Zoneline AZ55H07D Air Conditioner Logo
81 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
