I have a craftsman garage door opener and the chain came off the track. I've put the chain back on the track wheel but i had to loosen the chain to do so. now, when the door closes the bar bows up and the door opens again. how do i adjust the door?
  • Thomas F. Schneider May 11, 2010
    Your problem is listed under washing machine.
    I believe that thetr is an ajustment at the end of the chain?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
The reason your door is opening again is because there is a limit switch that is not making contact at the appropriate time to tell the drive to stop closing the door. The chain drive motor is controlled by a circuit that is expecting to see a signal telling it that the door is closed. If it doesn't see this signal to stop at the appropriate time, it continues to drive the door down unless it sees a certain amount of back pressure, which then tells it to return the door to the up/open position. This is a built in safety feature for most garage door drives and is industry standard now due to children getting caught under them and being killed. You can try this yourself. Stick a 4 foot 2x4 vertically under the middle bottom of the door as it's coming down, after a second or two the door will reverse direction.
With the chain falling off the drive and loosening it to replace it, you may have inadvertantly positioned the actuator of the switch, which is usually attached to the chain, out of position by a couple of links. There is a momentary contact switch mounted close to the door on the support shaft of the drive mechanism. This support shaft is the one holding the motor drive on one end, along with the chain and is anchored to the header over the garage door. This momentary switch may have a short metalic or plastic arm hanging down that is moved by the actuator on the chain and needs to be reset to a position where the switch contact will be closed when the door is in it's closed position. There are other options also depending on how new/old your door drive is. Some of the newer models use a through beam sensor or photo eye as a stop switch.
Please let me know if this helps.
Backyard_Jim
Posted on Dec 31, 2008
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
The chain came off my Craftsman 53920 garage door opener. How can I fix this problem?
When a chain comes off it is an indication of another problem. The bearing on the sprocket shaft is bad and lets the sprocket lean forward and the chain pops off. The part number you need is 41C4220A Gear and Sprocket Assembly. The chain can be loosened by the nuts on the trolley.
Sep 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door chain came off, i put it back on
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
The chain normally comes off when there is a problem with the sprocket and gear assembly. The bearing goes bad and lets the shaft lean towards the door and the chain comes off. If this happens again you will need to replace that assembly which is part #41C4220A and is available at any good door service company.
Jul 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
I just installed a sears craftsman 1/2 hp garage door opener. when i close the garage door with the remote the chain track bends up just about 12 inches before it closes all the way, and this only happens...
What is wrong is you need to adjust the limit on the door when it comes up. What it is doing is coming to far back on the track. You need to push the back limit forward away from the motor so the door does not come back and drop down on the inside of the garage. The opener is trying to push the door up hill to get it to close that is why you are getting the bend in the track.
Good Luck
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener and the chain came off trac
YES - YOU ALSO NEED TO BE SURE IT IS IN THE CORRECT POSITION WHEN YOU REINSTALL IT.
MOVE THE TRAVELER / TROLLEY TO THE CLOSED POSITION RUN THE OPENER TO THE CLOSED POSITION. LOOSEN CHAIN AND REINSTALL.
TIGTHEN CHAIN ONLY ENOUGH TO KEEP IT FROM SAGGING BELOW THE RAIL. (TOO TIGHT WILL RUIN THE BUSHINGS ON THE DRIVE).
NOTE; THE BUSHINGS MAY BE BAD THIS WOULD CAUSE THE CHAIN TO COME OFF OR SAG TOO FAR, LOOK FOR EXCESSIVE PLAY IN THE BUSHING UNDER THE CHAIN SPROCKET.
IF IT IS BAD A KIT IS AVAILABLE TO REPAIR.
HOPE THIS HELPS
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door openers old and new
yes yu can use the old track etc.
Jan 04, 2009 | Kitchen Appliances - Others
Bottom wheel of garage door came off track
Get a roller with a long stem. Then open door fully and clamp open. take off cable. unbolt botton bracket, insert roller into it and track, rebolt, reattach calble, that is it.
Sep 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
