Question about Frigidaire FEF352 Electric Kitchen Range
F1 error code on gas/electric Fridgidaire oven
After turning off my stove/oven on Christmas day(it had been on for over 6 hours) I received an F1 displayed where the temp/timer/clock normally appears. I hit clear off button and it sent away. I have not tried my oven since. Am I gonna have a problem when I turn it on tonight? I read that it was the circuit board? would it be safe to try and turn it on?
  • slambert11 Dec 31, 2008
    I turned it on and it seems to have lit with no problem. I guess I should just kkep and eye on it and make sure it does not display the error code again?????
    Sergeant:
  • 311 Answers
Yes it would only give another error code.board about 100$
Posted on Dec 31, 2008
  • Thomas Malailua
    Thomas Malailua Dec 31, 2008
    thank God and you can ask him to keep it going.happy new year
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Can not start my oven after self cleaning proceture
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 05, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Fridgidaire FGF 374 CCSA oven and broiler do not come on
F1 means it is a defective eeprom. The software is incorrect. Replace EOC. Check inside the bottom drawer on the right side: there was an envelope with the troubleshooting and maintenance diagrams in it.
Jan 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven beeping f1 and f3
Im having the same problem I have model arg71000 serial 9809185133 Hook me up with the solution please
Dec 22, 2007 | Kitchen Ranges
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
188 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
