Question about Panasonic PT-47WX53 47" Rear Projection HDTV
My panasonic big screen screen has shadows and fuzzy picture
I need to know how to clean the mirror and adjust the guns or whatever. The screen is blurry and has a double image slightly. to much red and fuzzy picture
  • Anonymous Feb 09, 2009
    my tv has a blue shadow
  • blue shadow Mar 25, 2009
    I have the same problem with the blue shadow on the bottom and top of the screen. Any advise? nelsonautoconsulting@comcast.net
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiMy panasonic big screen screen has shadows and fuz - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
My panasonic big screen screen has shadows and fuz - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
  • 90 Answers
Sounds like you might have more than one issue. Cleaning the mirror is just a matter of removing the top half of the back panel where the mirror is mounted and cleaning it. I'm not sure that will take care if any of the issues you described though.
Posted on Jan 07, 2009
Sony KP65WV60 CANNOT RECONISED RED COLOR AND WRITING FUZZY
First, try cleaning all your lenses & mirrors...THEN
considering the age of this unit, the red CRT is probably worn out. Weak CRTs are probably the problem with the fuzzy picture also.
You can try to adjust your screens (the screen adjusts are available by removing the bottom front) to bring in some red, and adjust the focus on each CRT for better focus. I'm thinking with the age of this unit you may need more than just the RED CRT.
If any parts are needed, My recommendation is to replace the unit with new technology. Would be more economical in the long run.
Apr 29, 2014 | Sony KP-65WV600 65" Rear Projection...
My sony kp65wv600 cannot see any red on people in pic and writing fuzzy
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My Hitachi 46F500 TV will not adjust either manually or in magic focus mode......it has green lines across top of screen and some red tinting in the picture ......is this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Picture has too much yellow and I cannot adjust it. I have taken the screen off the front and cleaned it but it didn't help. I can't tell blue from green
Go to menu, and tru to adjust it from there if not you're tv is getting old or it has some problems with the led lights inside its not possible to fix, you have to change tv
Dec 07, 2009 | Panasonic PT-47WX49 47" Rear Projection...
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Its a slight possibility that a 2.00 Part called a capacitor could be bad on the screen drive voltage source. But most likly it sounds like the Picture tubes are comming to the end of there life expectancy. If the crts are weak there is a crt rejuvinator that could possibly clean the grids off each color gun. But this is a crap shoot, as sometimes it destroys the tubes. These type of repairs are not for the handi-man or a consumer to do. There are no real user replaceable parts inside so unless your able to solder and know the HI Voltage saftey issues, you should call a pro to assist you in this repair. Good Luck
Jun 24, 2006 | Philips 9P6031C 60" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
1,272 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
