Question about Sony KDF-E60A20 60 in. LCD HDTV
Picture and sound stopping and resetting
Picture and sound turn off, then reset and come back on. It does it every few minutes. Is the lamp bad or loose? I tried tightening the screws, and it still does it. I took the lamp out and vacuumed the dust off it. It's not blown, but after reading other solutions, it seems this is a trademark of a "bad" bulb.
    Problem Solver:
  • 4 Answers
I went throught the same ordeal... When your picture goes out usually the light will flash red. The number of flashes usually will diagnose what is wrong. Mine was flashing 5 times. I would lose picture and sound for a bit and then it would repeat. I first took out the lamp and vacuumed it out. If the screen gets clogged it will overheat. This fixed it for about a month. Then same deal. I went and bought the repair manual off ebay and everything pointed to the lamp. when I checked the service menu, mine had about 8,000 hours on it. Manual says good for about 9,000 hours. I bought a replacemant bulb online and paid about 159, which included overnight delivery. I did this back in November. The problem has not returned. The only other source of the problem located in the manual was to replace a part about 269 dollars to 300 dollars.
Posted on Jan 03, 2009
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
The screen will not stop blinking. I can barely see the picture. Is there a reset button?
No reset button. Sounds like a bad Z-sustain board, everytime I've had a failure with a very dark picture, that has always been the board to fix it.
Jul 27, 2010 | LG 50PC1DRA 50 in. Plasma Television
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
HLP5067W Going on and off
Sounds like the bulb needs to be replaced. With the tv you have the Bulb last about 6000-8000 hours. If you think that is about right then you it most likely is time ro replace. You should be able to find the replacement bulb from the manufacture and then find it online to purchase.
Sep 20, 2008 | Samsung HLP5067W Television
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Sony KDF-E60A20 60 in. LCD HDTV Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
