Question about Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television
Remote not working even thought it was replaced with a new one...
You pointed me to two places to replace my remote, however the new remote does not work either and I am back to square one with this problem. Please help...
  • 1 more comment
  • Anonymous Jan 05, 2009
    I had programmed a learning remote to work with the TV, and now neither that or the original remote work to control the TV. Obviously the IR receiver in the TV is broke. Can't even get through to any kind of tech support.
  • Michael Jan 26, 2009
    AVC Tech, 777 Mark St, Wood Dale, IL 60191 handles service for this Hyundai LCD. They have the IR receiver for the HQL320WR and shipped one out to me. I was going to try to put the part in myself but will most likely look for a tech to do it instead. AVC can be reached at (630) 595-0123. They were very responsive and shipped the part out quickly once they received payment.
  • Qpeter Mar 27, 2009
    let me know wheae I can buy new remote?
Replace IR reciever module ,this only costs a few pounds but require some expertise.
Regards Bob. ps also check for dry joints on module.
Posted on Jan 25, 2009
Sony LC-C3234U Remote Problem
Check this after replacing the the batteries of the remote control with fresh ones. If the problem still persists, the remote control and the infrared sensor inside your TV [both] should be checked.
Dec 09, 2012 | Sharp Televison & Video
I can not get my remote control to work, even with batteries replacement
The remote can be tested---most shops or even electronics stores have a remote tester--point remote at it and press a button and strip on tester either lights up or not.
Also----some digital cameras when remote pointed at lens will show if remote is working(push button (any) on remote with camera on.
Mar 23, 2012 | Coby Televison & Video
My original remote for my Element TV has gone bad and the Universal that I bought for it will not work. Is there another place to get a Universal that will work>
Hello there,
If you're going to replace the remote, I would advise replacing it with an original Element remote. Finding a universal remote to work with Element TVs is purely trial and error - in many cases error!
I can help you to find either a replacement original remote or a universal that will work with your TV, but before doing so, you really need to check whether it's the remote that needs to be replaced. When TVs fail to respond to the remote control, it can be due to a fault with the infra-red (IR) receiver in the TV. Before buying a replacement, please test your remotes as follows:
1. Get someone to point the remote at you and press some buttons while you look through the viewfinder of a digital-camera or camera-phone. You should be able to see white flashes from the end of the remote through the viewfinder. This works better in a darkened room but it needs to be light enough for the digital camera to function.
If you don't have a camera-phone or digital camera . . .
2. Take the remote into a dark room - totally black works best. Point the end of the remote which you point at the TV towards you and press some buttons. You should be able to see faint red flashes emitted from the end of the remote. This is not to be confused with the indicator light near the top of many remote which illuminates when you press a button.
If the remote is working, it may still be possible to get the TV to respond again. Please try this first and let me know the results of the test. I will then be able to assist you in finding a replacement remote - or possibly even get the TV to respond again. Please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Feb 25, 2011 | Element Televison & Video
My remote control no longer works, even with new
First, test that the remote is actually working. The easiest way to do this is to point it at a switched on digital camera and look at the camera display. The remote uses infra red light which the human eye cannot see, but digital cameras can. As you press a button on the remote, you should see a glow coming from the remote in the camera display.
If it is working, it is probably a fault in your TV - not a DIY fix so take it to a repair shop.
If it isnt working, you'll need a new remote. A genuine Panasonic replacement will be expensive so you may opt for a universal one. However, universal remotes wont support all the functions the genuine one does.
Your choice !
Nov 02, 2009 | Televison & Video
JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Jan 12, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
Remote not working
I would bring the remote back and let the place where you purchased the tv know of your problem. They will probably give you a new remote. Most likely there is no problem with the television itself. Let me know what happens.
Cynthia Charczenko
Jan 15, 2008 | Sanyo DS20930 20" TV
Remote no longer works
the manual for this remote can be found on this site
http://www.fixya.com/support/p237065-ge_rm24930_remote_control/manual-11900/page-2
unfortunately i do not have a code list for this remote, but you should be able to use the code search function to get everything working again.
hope this helps,
trin
Nov 17, 2007 | GE RM24930 Remote Control
Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television Logo
155 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
