Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Gas leak I am looking for the leak, all the lines are wet but nothing is coming out of them.... maybe the fuel filter? Not sure where to find it. 1995 Chevy 1500 4x4 ext cab 5.7 L V8 with AC.
    President:
  • 1,990 Answers
Your Fuel Filter is on the Passenger side Underneath the Truck Inside the Frame Rail right about Even with the Door. Lines are VERY Easy to Follow from There.
Posted on Dec 31, 2008
  • Travis Humphries
    Travis Humphries Dec 31, 2008
    No Problem! Glad to Help!
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a 2006 Colorado truck with a strong gas smell out side the truck can you assist me
If you smell it at the rear of the truck. Most likely it is the vent solenoid stuck open. But it is best to see if the are gas trails on the tank. If so, it would be the seal for the sending unit in the tank.
Oct 08, 2016 | 2006 Chevrolet Colorado
Jingling sound from front of engine
Don't worry about the sound, Find the gas leak. Fuel lines come in on the drivers side. Then you have the injectors. on the fuel rail. on the fuel rail there is a pressure regulator. All this needs checked. Fuel lines on the engine are metal. BUT coming up to the metal lines, they are plastic. LOOK for wet spots.. FIX them. The regulator is on the fuel rail/ with the injectors. LOOK for wet spot at these locations also... There are also other locations under the car to find gas leaks....Fix this first...
Aug 19, 2014 | 2002 Ford Escort
What would give out fuel smell ?
did you check to see if your gas cap is missing?
Jul 13, 2014 | 2000 Ford Taurus
1996 civic smell gas all the time ,when driving,when parked,and never see any leaks.
You have to check for leaks under the car. Look at the gas tank, usually they leak but wont make it to the ground. If you see that the tank has any wet spots coming from the top around to the bottom, then the leak is at the sending unit. Follow the fuel lines up to the engine, looking for wet spots. Under the hood, find the fuel filter check this for wet spots, then check all the injectors, these can leak at the top or bottom, usually top. Best way to tell is start the car and then check the injectors. If they are leaking it could be a drip or spray.
Sep 25, 2011 | 1996 Honda Civic
95 chevy blazer vortec 4.3 changed fuel pump 2 days later it started to bog and sputter when giving gas change fuel regulator dont see any leaks or spray from the spider or the in lines they were replaced...
Check for a fuel filter problem..... sometimes the newer fuel pump can **** up debri from the bottom of fuel tanks that the old pump did not have the flow to **** up.
Jan 16, 2011 | 1995 Chevrolet Blazer
I smell strong gas fumes under the hood but dont see where it's coming from the truck is a 1996 chevy tahoe 5.7 liter
Gas leaks are sometimes hard to find with the complexity of components, hoses etc. on today's cars. The other difficulty is the evaporation of fuel can be almost spontaneous due to the heat in the engine bay area. I look for signs with the engine COLD and the ignition on, fuel pump pressurized, then off. It should hold pressure. turn the ignition back on at it should only run the pump amoment, not as long as the first time. If it does run just as long you may have other problems as well. With the pump pressurized and ignition off, look carefully at all fuel line connections especially when rubber fuel lines and clamps are used. Your finger and your nose may be the best method in hard to see areas. Don;t forget to check the return fuel lines back to the tank and any filters or canisters in the system. look for darkened or wet areas on rubber hoses and wet fittings on metal lines.
This is not something to play with. Find it or get help pronto. It may cost you your vehicle and maybe even your life. Gasoline fires are nothing to flirt with.
Sep 21, 2009 | 1996 Chevrolet Tahoe
1983 Dodge Ram Charger quadra jet carburetor, gas not getting to carburetor. starts, runs, quits running.
tienes que checar la bomba de combustible remueve las lines de entrada y salida de gasolina y da marcha si avienta gasolina si sirve si no tienes que cambiar la bomba de combustible se encuentra adentro del tanque
Sep 08, 2009 | 1990 Chevrolet Beretta
ENGINE IDLES ROUGH, BUT RUNS FINE WHILE DRIVING. My car is a 1995 Buick Regal Gran Sport with the 3800 series motor with 212000 miles. The rough idle tarted after driving through some muddy and wet roads
go the cheapest route. replace fuel filter and add SEAFOAM to tank of premiun fuel. replace filter before 500 miles. then add SEAFOAM to gas every 3000 miles to keep lines.engine,fuel pump, and emissions systems clean, ETHANOL problem number 3000
Aug 29, 2009 | 1995 Buick Regal
Acts like its running out of gas, raw gas smell
this suggests you have a fuel leak in the engine compartment. Possibly a leaking fuel manifold (injection rail), or the rubber line from the fuel tank is leaking where it attaches to the manifold. The fuel line to the cold start injector should also be checked. Rubber hoses on older cars become brittle and as they contract from very cold weather will leak. Turn the key to on for 1 minute but do not start the car. Then check under the hood for a raw fuel wet spot where the leak is.
Jan 10, 2009 | 2002 Subaru Outback
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
81 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
