Question about Panasonic KX-FPG372 Plain Paper Thermal transfer Fax
Phone rings once (only... and weakly) then shuts down.
Checked the battery, and replaced it with factory supplied new one. No change. One weak phone ring, then if I grab it, I can talk. If not, it does not activate the answering machine. Checked all the 'contacts' and found not dirt/grime. The fax/phone is only 3 years old. ??? thanks for any suggestions, alan
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 171 Answers
HAVE YOU CHECKED WHETHER THE MACHINE IS SET TO CORRECT ANSWERING MODE ??? HAPPY FAXING OMNIPRESENT
Posted on Sep 23, 2007
Alt. charges 2or 3 min. then shuts down new alt. new comp.
Check wire going from alternator to battery could have a short. Did you replace belt and tensioner it
May 10, 2016 | 2005 Mazda 6 2.3
2002 Lancer I was driving the lights and motor shut off once I got a jump it started right back up 5 miles the lights went off the motor started spitting and sputtering shooting sparks out the back
Have the charging system checked for proper operation. If battery is not being charged properly and goes weak the electronic control modules within the vehicle will start shutting down and cause all sorts of drivability issues
May 03, 2015 | Cars & Trucks
Power button shutting off as soon as i try to switch on
Shut down
Unplug the power supply.
Remove the battery.
Insert power cord
Reboot with power cord but no battery
If it comes up, your battery is dead or weak
Replace the battery.
If you don't even get a flash, your power supply may be bad.
Get a new power suppy.
If it continues the restart cycling, then there's something wrong elsewhere.
Jan 01, 2013 | HP Mini 1000 Netbook
Once the unit is charged how long does the battery run dry
Once fully charged, it will last for about 4 hours, if it is used without shutting down. The good thing is that it comes with a rechargeable lithium ion battery. That can be recharged once it is weak. I will strongly advice that you do not allow the battery run down completely before recharging as the battery might become weak and unable to hold a charge. So do not let your gps die before recharging. you can charge once it is low.
Dec 24, 2010 | Nextar X3-03 Car GPS Receiver
My phone keeps turning off two or three seconds after I just barely turned it back on.
Hello,why the phone is still shutting down is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
If not battery, in think you will have to flash the phone memory for it to come back to life.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has VIRUS and has affected the phone memory.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Sep 16, 2010 | Nokia 5310 Cellular Phone
When a call come i receive the call battery singnle low and switch off the mobile
Battery problem
Take care.
Aug 16, 2010 | Nokia N70 Cellular Phone
Nokia 1600 suddenly battery low when switch on battery full. solution plz
Sometime replacing of battery is right, it is more costly So you better go to mobile tech or you can do this.78bf4b2.jpg
Aug 12, 2010 | Nokia 1600 Cellular Phone
My battery life is great as long as i dont text or call anyone. My phone can retain power if it is not in use. Everytime i attempt to make a three minute call my phone shuts down after a certain amount of...
Take care.
Jul 02, 2010 | LG Vu CU920 Cellular Phone
Lost dial tone
is your unit is new?or your battery is new?if not,then it is probably your battery is weak.you cant say that a battery is GOOD if it still accepting a charge when you are going to charge...let me say that even if a power is stored on it ,you still can't say that it is still good.Becoz when a battery is weak,its current or ampere will become lower than the given specification when it was new.Thus,when a current is low,a batery can no longer supply the exact needs of the unit during the time of conversation,and thats the reason why it will shut down in just almost a minute of conversation even you know that it was fully charged .
Oct 27, 2009 | Uniden 5.8GHz Dual Cordless Phone
I have the same problem
your batterry is too weak or weak amperage for your cellphone you need to replace it a new one battery.
Aug 01, 2009 | LG enV2 EnV-2 VX-9100 VX9100 Premium Pink...
Panasonic KX-FPG372 Plain Paper Thermal transfer Fax Logo
146 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
