Question about Clarion DXZ865MP CD Player
My radio wont turn on
I installed my radio and to cross the hot wire and the aux wire to get the radio to power up. I have installed many radios in the past but never ran into this problem. If i keep the wires crossed obviously the radio wont turn off with the ignition.
    New Friend:
  • 57 Answers
Sound like you have a bad fuse in your aux wire check to make sure your aux wire has power when ignition is on if not check your fuses in your car start with the radio but it could be drawing from another fuse like cigar lighter good luck.....
Posted on Jan 10, 2009
98 ford 150 4x4 Starter staying engauged! Is there any way I hooked up a wrong wire in my new radio installation that would cause that to happen? It was fine until I installed my new radio and now the...
You are some how putting power to the switch side of the solenoid on the fire wall. Take a test light and check the S switch side of the solenoid, it should only be hot when the key switch is turned on. It you have crossed this wire inside them you may be making this wire hot all the time. I would re check how you wired your radio.
Dec 31, 2014 | Cars & Trucks
2013 steetglide radio wont work fuse good
"wont work is to vague.
Contact Ion Cross Audio for more help
Jul 03, 2014 | Harley Davidson 426290 AM/FM Radio
Cobra 18rv cb has 3 power wires, what is the yellow, (aux) wire for?
The red lead (switched) turns the radio on when the ignition switch is turned on and off when the ignition switch is turned off. The orange wire is used to keep power constantly going to the radio so you don't lose the last channel you were on, and it gives you emergency weather information even if the radio is off. If you want the radio to stay on all the time even if the ignition switch is turned off then you can just put both wires to a constant power source like directly to the positive post of the battery or an un-switched connection on the fuse panel, and you just turn it off with the volume/power switch. But you have to remember to turn the radio off or you could drain the battery in a few days. So the choice is yours. :)
Apr 17, 2014 | Cobra Radio Communications
1994 honda accord radio wont save settings.
If you have a multimeter or test light, try to find a wire that still has 12v when the key is off. Connect that wire to the yellow wire of the radio. The yellow wire has to have constant voltage going to it to maintain the memory.
Feb 11, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
2005 chevy cavalier after market radio has no power, im installing a pioneer head unit in my car, i bought a wairing harness connected it to the wiring harness for the new radio, im getting power to the...
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Sep 03, 2011 | Car Audio & Video
1993 mercury cougar radio blows when insalled pleeeeze help
Make sure your ground wire at the car did not get fried to a hot wire. It may have fire. That is the only reasonable thing it could be if it is blowing radios...
Jun 19, 2009 | 1993 Mercury Cougar
The radio wont turn off when i turn the key
You could be hooking up the main power to a full time hot rather than the radio circuit. Use a test light to find the switchable hot and hook up your power wire to it, then then memory for the radio goes to the full time hot.
Apr 14, 2009 | 1991 Chevrolet S-10 Blazer
Use a voltmeter or a circuit tester. 2-5 bucks anywhere worldwide.
Test the power wire from the radios wire harness for power.
If It shows power then you fried your radio.
If It shows no power from the Harness. Hopefully you just cooked the radio harness. Splice the power wire off of the radio harness and test It for power cross your fingers thats as deep as you have to go Into electrical system.
Test the radio power wire that goes to your radios harness for electric current.
When you find the power the garbage will present Itself.
Before any of the above check all of your fuses.
One thing Is for sure you def blew something.
Good Luck
Mar 22, 2009 | 1996 Ford Explorer
Alpine IVA-D310e radio problams
More than likely you got some wires crossed. The Aux or Accessory(usually the red wire, stays hot all the time so the radio can save your presets) the yellow wire is usually the main power. I would go back through your wiring and make sure no wires are crossed. I'm going on my experiences with installing radios and other equipment. hope this is helpful, if not sorry.
Mar 13, 2009 | Alpine Car Audio & Video
Dual XDMR7710 player wont save settings
Cut the red and yellow wires and cross them to the opposites and connect again and this will save your cd players memory
Mar 11, 2008 | Dual XDMR7710 CD Player
Clarion DXZ865MP CD Player Logo
185 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
