Question about Food Mixers
I want to buy some oil to lubricate my hobart slicer .what to use
The hobart slicer is stiff
  • Salvadorc750 Jan 13, 2009
    My Horbat work to slow and the motor oil is old. What kind of oil should I use?
    President:
  • 2,976 Answers
If you can, remoove the blade - very carefully. Clean everything where you can. It's a virtual trash holder under the blade. Where the blade mounts, you can use mineral oil to lubricate the bearing. If it makes any contact with food, it won't hurt you.
Posted on Jan 03, 2009
HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
May 08, 2008 | Hobart A200 Stand Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
I have a v1401 and its oil level is low. Where
you can buy @any hobart office in your area.
Jan 15, 2010 | Food Mixers
Hobart D300 Mixer: Has no torque and no speed in any gear
You have a gear with broken teeth or one sliding out of place because the brass shims are eaten up. Hobarts have what is called a planetary, round head where the grease caps are, and there are no clutches for this planetary. These units are not made to change gears while unit is running (#1 problem of gear failure) (#2 is overloading the bowl) Hobarts need a really stiff GREASE, not oil. If you decide to take the planetary apart, get all the syrup out and replace with a stiff axel grease. It is a very difficult job replacing a gear & ALL the shims. The round head where the grease caps are can easily be removed to do this.
Jun 17, 2009 | Hobart D300 Stand Mixer
Worm gear hobart slicer
What is the model number?
Apr 06, 2009 | Hobart N50 Stand Mixer
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Aug 07, 2008 | Hobart N50 Stand Mixer
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
634 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
