Question about Dell Dimension 4500S PC Desktop
Error message For the past couple months I get an error message when I startup. I must hit cancel 12 times before it disappears. Theneverythingworks normally. The error message title block says ''Windows - no disk'' Then the error message starts Exception processing message Followed by: c0000013 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c
    Problem Solver:
  • 14 Answers
"UPDATE - summary added, history moved to end: This problem seems to be caused either by malware (virus or spyware etc), or by software following a Windows update or some other software installation or uninstallation (particularly HP, Norton or QuickTime software) trying to check for removable media that isn't there (e.g. disc in DVD drive or card in card reader), when it shouldn't be doing that check."
source: http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
another tip try running "search and destroy"
Posted on Dec 31, 2008
I have a HP C6100 All in One error Oxc18a0206 ink failure
Remove all supplies, switch off the machine remove power & usb cable wait couple of minutes.. Power on the machine install the supplies as per appears on screen, check for the error.. For tech guys:
Remove CMOS battery from the formatter, wait for 15 mts, with out battery check for the error. Once error disappears, add CMOS battery...
Jan 04, 2012 | HP PhotoSmart Office Equipment & Supplies
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Error messages
hm sounds like a virus. maybe your antivirus program deleted a virus recently?. try this.
click start->run-> write "msconfig" and the click startup.
search for C:\Windows\system32\Virus removal.vbs and uncheck.
restart the computer.
dont worry about the popup window that popup first time after restart check dont show this again.
second problem.
what dvd program are u using ? try a other one.
it can be that the dvd writer have errors:S
Jul 17, 2008 | Microsoft Computers & Internet
Emerson EWR20V4 that wont record DVD's
Sure, My suggestion is to call 1-800-605-8453, They will be glad to help you with that error code!
Good luck
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dell Dimension 4500S PC Desktop Logo
132 people viewed this question
Alun Cox
