Question about RCA F27648 27" TV
My rca tv
All i get out of tv is stactic but when i put a dvd in player i get sound from that just not my cable tv
I HAVE A TV RCA MODEL NUMBERF27648. IT WILL ASK FOR THE G LINK. WHAT IS THIS?
Posted on May 01, 2010
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
No picture
Make sure the yellow RCA cable is connected in both the DVD player and TV. Make sure the TV is on the proper input that you see the DVD player connected to. If you're getting sound and no picture, try using new/different RCA cables.
Jun 16, 2011 | Philips DVP642 DVD Player
How do I connect my lg drt389h dvd recorder to my ferguson fl26wx1 tv. I can play dvd's but i'm unable to record anything from my sky box.
Hi, When you bought your DVD player it comes with 1 type of cable. RCA type cable 2 audio and 1 video. Yellow for video and red and black for audeo. Your TV should have RCA plugs on back and match them up with DVD player. Most DVD player now come with optical out put, TV must have input to complete. If you have that you can get better sound from them. Good luck
Jun 15, 2011 | LG Televison & Video
I have an external DVD player. When I plug it in the back of my RCA 20" TV/DVD combo, model BD20TF10 through rca cables there is only sound and no video. When I plug it with an S-video cable I get...
Ok, this seems to be a common problem amongst us techno-phobic couch potatos ( just kidding), sounds like tv input is not selected on right channel input. make sure pins on s-video are not bent or missing, if they are, you need a new s-video cable, try connection through the red/white/yellow cables, make sure that you have correct input selected on tv set ( example: S-video, component1 , aux 1,HDMI1, and so on.) put dvd in player and keep going till you get the right one. in ,my experience, the R/W/Y cable is component1 and of course, s-video, is well, s-video, kinda self explanatory...
Oct 17, 2010 | RCA BD20TF10 20 in. TV/DVD Combo
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
I just bought a RCA rtd3131 home theater system. My husband trashed the manual and i can't get all the speakers to work when the cable is on. When the DVD is on all the speakers work but the sound is not...
If the cable tv has audio out jacks, or if you have a cable box with an optical audio cable, plug either the audio jacks into the RCA system or the optical audio cable, and the system should automatically simulate 5.1, through Dolby Pro Logic II. All speakers will not be at the same volume as they are simulating surround sound, not just playing the audio.
The TV will never have sound for the DVD as this system has no audio out puts. Realistically, most televisions have 10w speakers, and this system is 130w, so the TV speakers are useless in comparison.
Jun 28, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
RCA F27648 27" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
