Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Stuck on startup screen.
I've tried restarting with the back and the d-pad left.
I've tried restarting with the back and the d-pad up.
I've tried restarting with the back and the d-pad down.
And I've tried holding down the play/pause button to turn it off.
None of these got it off of the startup screen.
Please help! My 30 G Zune also froze today!!
I guess MS and Y2-K9 are both dogs. If anyone knows of a fix please passs it on...I'm thinking of throwing my brick through a window...but then I'd have to replace a window and a typical malfunctioning MS product.
  • 1 more comment
  • Anonymous Dec 31, 2008
    all of thezune in the same date
  • part851 Dec 31, 2008
    Frozen at the start up screen. The progress bar gets about 95% of the way and then the thing just stops. Doesn't react to anything. I tried running the battery out and recharging to no avail.
  • randalljo Jan 01, 2009
    Ummm... I'm with you. My zune just randomly died today.
So it turns out many Zunes have had this problem including mine. Here are the official suggestions from the Zune Website.
My Zune 30 is frozen. What should I do?
Follow these steps:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
Once the battery has sufficient power, the player should start normally. No other action is required—you can go back to using your Zune!
There ya go.
Posted on Jan 01, 2009
Http://www.foxnews.com/story/0,2933,474690,00.html
see this story
    Problem Solver:
  • 4 Answers
Pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Posted on Dec 31, 2008
Toshiba leading innovation
Hi Branden,
Could you please try to remove the battery and wait for 30 sec. Again insert the battery and turn on the machine after 30 sec.
Regards,
Samy
Aug 10, 2014 | Toshiba SATELLITE C855-S5900 Laptop Screen...
Lg laptop recovery startup
Try to connect an external mouse to see if that works. Also, many laptops have a lock for the touchpad. Normally one of the F keys along the top will have a button that looks like a touch pad / touch pad with an x on it. You may or may not have to press the FN key (usually bottom left on keyboard) while to press the necessary F key. this should unlock your pointer.
Nov 13, 2013 | LG Computers & Internet
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
Jun 26, 2017 | Apple iPhone 3G
I have a gateway gt5622 to will not boot beyond the screen that says starting windows. I have tried updating the bios, changing the power supply, changing the memory, disabling usb in bios, and nothing...
If your system is stuck on the Windows Start Screen Screen you can try to boot using Safe Mode by restarting the computer and tapping F8 while it is booting. When it successfully load the Operating system you can disable some startups on the machine. Click on Start then click on RUN, type MSCONFIG on the dialog box located on the lower left of your screen. Then Click on the SERVICES tab. Put a tick on Hide All Microsoft Services then click on Disable All button. Disabling some startup software may fixed the problem. Restart the computer see if it will works. If not then you need to Reinstall the Operating System to your machine.
Thanks for using Fixya.
Jan 27, 2011 | Gateway GT5622 PC Desktop
My Eee PC wont boot up....it is stuck on the window xp logo screen. Ive tried powering off/on and removing battery. Any help would be greatly appreciated!
If your system is stuck on the Windows Logo Screen you can try to boot using Safe Mode by restarting the computer and tapping F8 while it is booting. When it successfully load the Operating system you can disable some startups on the machine. Click on Start then click on RUN, type MSCONFIG on the dialog box located on the lower left of your screen. Then Click on the SERVICES tab. Put a tick on Hide All Microsoft Services then click on Disable All button. Restart the computer see if it will works. If not then you need to Reinstall the Operating System to your machine.
Jan 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Black screen startup
hello..this is the 1st you need to try..if you have a CRT monitor or LCD Screen try to put the signal Video on the Laptop located at the Back of unit then try to boot your unit...Thanks...
May 10, 2009 | ASUS G1 Notebook
Hello my friend, I was about to throw my zune to the trash but I thought, what the hell let's open this piece of ****. So I looked up for a video in youtube: http://www.youtube.com/watch?v=pJwLn75RQRM, this guy teaches you how to change your zune hard drive, it's preaty cool. So I opened my device and first I disconeccted and connected both cables (Battery and the other one I don't know what it is...), started up my device and walahh!! it worked. I hope it works for you!
Eduardo Mexico
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Stuck on the restart your computer screen.
You may have installed something in the startup items folder that your mac isn't liking.
When you turn the iBook on, press the shift key as soon as you hear the startup tone. hold it down until you see the gray apple screen. This will get you into safe mode, hopefully then you'll be able to fix whatever you did from there. If you are still at a loss, get in touch.
Dec 11, 2008 | Apple iBook G4 Mac Notebook
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
316 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
