Question about Compaq Presario C700T Notebook
How do i connect
Which cable do i use to connect my laptop to tv
    President:
  • 1,179 Answers
It all depends on your video card & TV. You might be able to use a hdmi cable if both support hdmi. If your tv has hdmi & your computer has dvi you can get a hdmi to dvi adapter to plug into your computer. Hope this helps.
Posted on Jan 01, 2009
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Jan 18, 2013 | Toshiba Satellite L675-S7044 Notebook
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
Laptop connection to TV - Sound Problems HELP!
#Select the best HDTV package for PC and laptops to suit your needs. #Plug HDTV USB Stick into any USB port on your computer.
#Connect your Antenna cable, cable TV cable, or satellite cable to your HDTV USB stick.
#Install your TV tuner software.
Jan 14, 2010 | Sony VAIO (PCWA-A200)
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Laptop connected to TV via 23pin cable and setup
You have to connect the laptop to the TV by using the headphone jack on the laptop.
Only then, will the sound be sent over to the TV, and automatically the speakers on the laptop will stop working.
Get a cable to connect them from the headphone jack to an appropriate input on the TV.
Hope I helped,
Tom
Jun 21, 2009 | BenQ Computers & Internet
What type to cable should I buy to connect laptop to tv
Youre laptop would have to have a video card that has a TV-out port... And for that you would have to run a S-Video cable from the TV-out port of your laptop to the S-Video port on your TV... I assume your TV has a S-Video port?
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
How do I connect my HP Pavillion dv9700 laptop with my Sony TV KV 32HV600? TV has DVI-HDTV-In and s-video with 4 holes. My laptop has s-video with 7 holes, another port with three rows of five holes, and...
You need s-video cable or VGA cable (if VGA ports are available on your laptop and TV) to connect your laptop to the tv.Connect the one end of your cable to your laptop port and another end to the tv port.and then set your tv to s-video mode.
Thanks
Mar 03, 2009 | Computers & Internet
Compaq Presario C700T Notebook Logo
139 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
