F4 error code onmodel gsx9885jq0 whirlpool washer
Will not advance to wash cycle
  • Anonymous Mar 29, 2014
    Why is my whirlpool gold series washer flashing f4 error code?
    Scholar:
  • 140 Answers
Hello, Let's see if I can help.Try this first.
1.
Press Pause/Cancel twice.
2. Open and close the washer lid.
3. Reset the cycle and press Start.
If the problem persists, press Pause/Cancel twice to clear the
display. Call for service.
Posted on Dec 31, 2008
What does f mean on my cabrio washer, just f
your not reading the error codes right, the F simply stands for fault then the other lights indicate a number code like f2 f4 or f5 etc Whirlpool Cabrio Washer Error Codes Repair Help Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis
Dec 21, 2016 | Washing Machines
Getting error E1 checked all as per manual but still getting it
Whirlpool dishwasher F4 F8 FA error code ... - YouTube
? 1:57
www.youtube.com/watch?v=RfeFTdSdNYQ
May 27, 2012 - Uploaded by ukanfixit Although the Whirlpool dishwasher F4 error code is "not draining" it is actually a .... switch situated? my Whirlpool showsE1 and F8 error codes.
Aug 24, 2015 | Whirlpool Dishwashers
What does F4 on the display mean?
If "F4" through "F16" appears on the display, there is an electrical problem with the washer. Press the "Pause/Cancel" button twice to stop the washer and press the "Drain/Spin" button to drain any excess water in the machine. Select the cycle again and press and hold "Hold to Start" to restart the washer. This should clear the error and return the washer to normal operation.
If any of the error codes persist, the problem with the washer may be serious. Contact a qualified service technician to repair the washer.
Read more : http://www.ehow.com/way_5389738_whirlpool-duet-troubleshooting.html
Jul 06, 2014 | Whirlpool Washing Machines
My Whirlpool Cabrio WTW5500 stays on wash cycle and will not advance
I think it could be your main board, but first open it up and check the many connectors to ensure that are seated correctly.
UNPLUG THE MACHINE BEFORE SERVICEING
http://www.appliancepartspros.com/parts-for-whirlpool-wtw5550xw0.html
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I HAVE A WHIRLPOOL GSX9885JQ0 WASHER AND THE BASKET WILL NOT SPIN. PUT A NEW TRANSMISSION IN AND IT IS STILL LOCKED UP?
Maybe check and make sure that the door switch is working properly I know most washers will stop spinning if you open the door during the cycle, so that goes to say that if the switch is bad it will not start to spin as it thinks the door is open.
Mar 27, 2011 | Washing Machines
My whirlpool gold model gsx9885jq0 will not spin.
I was amazed at the excellent utube video on washing machine repair, I expect you will find your solution there. For your encouragement, it's not likely to be the timer.
Nov 20, 2009 | Washing Machines
Washer won't start to agitate or drain the water
this could be caused by a bad motor.
  • but i would first check the wire harness that goes to the motor and make sure it has not worked loose.
  • you should be able to see it from under the machine.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Washing Machines
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
what is your model # i looked at the manual there is no F4 code they only go up to F3 if you post your email i will send you the service guide
May 20, 2008 | Whirlpool Washing Machines
Washing Machines Logo
866 people viewed this question
Top Washing Machines Experts
